    HELP-Bugsplat don t let sketchup run
    9 Posts 5 Posters 1.7k Views 5 Watching
    • ely862meE Offline
      ely862me
      Bugsplat exactly after starting the sketchup.
      It happens with both versions 6 and 7.
      If happens with both..i suppose there is a program that makes them doing this..
      What i ve seen lately wrong in sketchup is that when i was saving a model the style was changing..other than that i m 😲 ..now i must reinstall both applications.. πŸ˜•
      Thanks!
      Elisei (sketchupper)
      Come and See EliseiDesign
      • ely862meE Offline
        ely862me
        Sketchup 7 reinstalled and still same problem..now i need to uninstall other programs that i ve installed lately ..
        • ely862meE Offline
          ely862me
          I find out which program provoked the sketchup...now the problem will be why??
          The program is Netdog..now Google : Read this and fix this!
          Elisei
          • BurkhardB Offline
            Burkhard
            Can you explain a little bit more?
            Since yesterday SU freezes by start. No chance to get it to work.
            I made a fresh installation without my own folders and it works. What's netdog?
            Burkhard
            http://www.ia-plus.de
            • ely862meE Offline
              ely862me
              when i was starting the sketchup the bugsplat was appearing after few seconds before the main window of sketchup load.
              The netdog it s a program wich don t allow u to enter the adult sites.
              After i uninstalled it all worked fine.
              Elisei
                What's your problem with adult sites? πŸ˜’
                See, even SU likes them! πŸ˜„
                  Jim
                  Have you tried to configure netdog to allow SketchUp to use the network?
                    bjanzen
                    If you do crash and you do suspect Netdog, could you please indicate so and send in the crash report? I'm looking at them, and it's not immediately clear how it's crashing. Thanks.
                    b
                    • ely862meE Offline
                      ely862me
                      ok..i ve installed the program again and it happens the same..i ve sent the error report with the description of the error..hope u can fix this inconvenient .
                      Cheers!
                      Elisei
