    Textures without Shading?
    4 Posts 3 Posters 4.4k Views 3 Watching
    • O Offline
      Osoleilmia
      Hello!
      I'm trying to create elevation plans showing wall textures, but without wall shading. I see there are view options for shading + texture, and shading - texture, but no texture without shading. Any ideas?
      Thanks!
      • Chris FullmerC Offline
        SketchUp does not like to turn off its shading. But you can get it to work, at least get pretty close (I'm not sure if its really 100% off, but it looks like it is) by doing the following:
        Use shaded with textures on.
        Open the shadow dialog box.
        Turn on "Use Sun For Shading"
        Slide the "light" slider down to 0 and "dark" slider all the way up to 100.
        That will get you pretty good, shader free, textured, faces.
        Chris
        All my Plugins I've written
        • O Offline
          Osoleilmia
          Thank you so much! That works wonderfully!
            LSA232
            Thanks a ton, you saved me from masking all shots in Photoshop to remove these shadings πŸ˜„
