    Textures without Shading?
    4 Posts 3 Posters 4.6k Views 3 Watching
    • O
      Osoleilmia
      Hello!
      I'm trying to create elevation plans showing wall textures, but without wall shading. I see there are view options for shading + texture, and shading - texture, but no texture without shading. Any ideas?
      • Chris FullmerC
        SketchUp does not like to turn off its shading. But you can get it to work, at least get pretty close (I'm not sure if its really 100% off, but it looks like it is) by doing the following:
        Use shaded with textures on.
        Open the shadow dialog box.
        Turn on "Use Sun For Shading"
        Slide the "light" slider down to 0 and "dark" slider all the way up to 100.
        That will get you pretty good, shader free, textured, faces.
        • O
          Osoleilmia
          Thank you so much! That works wonderfully!
          • L
            LSA232
            Thanks a ton, you saved me from masking all shots in Photoshop to remove these shadings πŸ˜„
