    Menus disabling
    1 Posts 1 Posters 730 Views 1 Watching
    • thomthomT
      I've run into an issue where my plugin (Selection Toys) caused SU to disable menu items in the context menu.
      It started after I added filters for layers. It'd dynamically create two menu items per layer. The occurrence is erratic and there's no error messages. When I disable the feature things return to normals.
      You can follow the discussion here:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=14975&start=90#p174356
      To reproduce it you can uncomment the lines 292-294 and 318-320 (v1.13) in the script. I can't see anything wrong with the code so I suspect it's a SU bug. (Or maybe a Windows bug? http://forums.sketchucation.com/viewtopic.php?f=180&t=20791#p175253)
