    Exit/Shutdown SU 7 ??
    14 Posts 7 Posters 3.7k Views 7 Watching
    • H
      HPW
      Can I shutdown/exit SU 7 with ruby?
      How?
      • J
        Jim
        Not directly, but you might be able to make a system call that could shut it down.
        • H
          HPW
          After some googling I found a post with the same problem:
          http://groups.google.com/group/Ruby-API/browse_thread/thread/227bae3cdb6f84a3
          I still wonder that such a big API still miss such basic things.
          Automating Autocad is still much easier.
          • H
            HPW
            I tried the API-call from that link.
            But unfourtunatly it does not work from a ruby loaded on startup.
            When I type it from the Console after startup it closes SU.
            • H
              HPW
              After the problem with the Win32Api-code I searched further and found:
              http://rubyonwindows.blogspot.com/2007/05/automating-applications-with-ruby.html
              require 'win32ole'
              wsh = WIN32OLE.new('Wscript.Shell')
              if wsh.AppActivate(skpbasename+".skp - SketchUp")
                wsh.SendKeys('%{F4}')
              This works for me now.
              • BurkhardB
                Burkhard
                We have a lot of Bugsplat possiblities to close SU7. ie. it could be easier to create a ruby which select all same materials, set Podium reflection at once. Sketchup closes immediately. πŸ˜‰
                http://www.ia-plus.de
                • A
                  AlexMozg
                  How?
                  def Sketchup;;exit
                      model = Sketchup.active_model
                      model.save "temp_model.tmp" if model.modified?
                      Sketchup.send_action 57602
                  end#def
                  Model doezn't realy save.
                  πŸ˜„
                  • W
                    wikii
                    Following ruby code works PC.
                    system("taskkill /im sketchup.exe /f")
                    • H
                      HPW
                      Undocumented feature but it works.
                      The doc shows:
                      21560 and up: causes a runtime Error
                      So is it official and where do you find such things?
                      Works but shows a cmd-window and is slower.
                      • thomthomT
                        hmm.... what if you have other SU windows open at that time.. kills them too?
                        • H
                          HPW
                          Another point to use one of the other methods.
                          For now I will go for the Sketchup.send_action which seems to be the best/smallest option.
                          • H
                            HPW
                            I revert back to the:
                            because:
                            immidiatly shut down SU even when the save-process is not finished.
                            So its get not saved.
                            • Dan RathbunD
                              Dan Rathbun
                              [code] Sketchup Safe Shutdown method
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=29162&p=254022#p254022
                              cross-platform and safe.
                              I'm not here much anymore.
                              • Dan RathbunD
                                Dan Rathbun
                                @alexmozg said:
                                > def Sketchup;;exit
                                > end#def
                                Do NOT use exit as a method name !!!
                                It is already defined as a global method by the Kernel module (and so is inherited by ALL classes and modules.)
                                exit() Initiates the termination of the Ruby script by raising the SystemExit exception. Also runs any at_exit block methods before termination.
