Exit/Shutdown SU 7 ??
Can I shutdown/exit SU 7 with ruby?
How?
Not directly, but you might be able to make a system call that could shut it down.
After some googling I found a post with the same problem:
http://groups.google.com/group/Ruby-API/browse_thread/thread/227bae3cdb6f84a3
I still wonder that such a big API still miss such basic things.
Automating Autocad is still much easier. -
I tried the API-call from that link.
But unfourtunatly it does not work from a ruby loaded on startup.
When I type it from the Console after startup it closes SU. -
After the problem with the Win32Api-code I searched further and found:
Automating Applications with Ruby & The Windows Script Host
We've talked at length about automating Windows applications through COM/OLE, using the win32ole library. But not all applications expose t...
(rubyonwindows.blogspot.com)
require 'win32ole' wsh = WIN32OLE.new('Wscript.Shell') if wsh.AppActivate(skpbasename+".skp - SketchUp") wsh.SendKeys('%{F4}') endThis works for me now.
We have a lot of Bugsplat possiblities to close SU7. ie. it could be easier to create a ruby which select all same materials, set Podium reflection at once. Sketchup closes immediately.
How?def Sketchup;;exit model = Sketchup.active_model model.save "temp_model.tmp" if model.modified? Sketchup.send_action 57602 end#defModel doezn't realy save.
Following ruby code works PC.
system("taskkill /im sketchup.exe /f") -
Undocumented feature but it works.
The doc shows:
21560 and up: causes a runtime ErrorSo is it official and where do you find such things?
Works but shows a cmd-window and is slower.
hmm.... what if you have other SU windows open at that time.. kills them too?
Another point to use one of the other methods.
For now I will go for the Sketchup.send_action which seems to be the best/smallest option. -
I revert back to the:
because:
immidiatly shut down SU even when the save-process is not finished.
So its get not saved. -
[code] Sketchup Safe Shutdown method
http://forums.sketchucation.com/viewtopic.php?f=180&t=29162&p=254022#p254022cross-platform and safe.
@alexmozg said:
> def Sketchup;;exit > model = Sketchup.active_model > model.save "temp_model.tmp" if model.modified? > Sketchup.send_action 57602 > end#def >Model doezn't realy save.
Do NOT use exit as a method name !!!
It is already defined as a global method by the Kernel module (and so is inherited by ALL classes and modules.)
exit() Initiates the termination of the Ruby script by raising the SystemExit exception. Also runs any at_exit block methods before termination.
