    Exit/Shutdown SU 7 ??
    14 Posts 7 Posters 3.8k Views 7 Watching
    • H
      HPW
      After some googling I found a post with the same problem:
      Error 404 (Not Found)!!1
      (groups.google.com)
      I still wonder that such a big API still miss such basic things.
      Automating Autocad is still much easier.
      • H
        HPW
        I tried the API-call from that link.
        But unfourtunatly it does not work from a ruby loaded on startup.
        When I type it from the Console after startup it closes SU.
        • H
          HPW
          After the problem with the Win32Api-code I searched further and found:
          (rubyonwindows.blogspot.com)
          require 'win32ole'
          wsh = WIN32OLE.new('Wscript.Shell')
          if wsh.AppActivate(skpbasename+".skp - SketchUp")
            wsh.SendKeys('%{F4}')
          This works for me now.
          • BurkhardB
            Burkhard
            We have a lot of Bugsplat possiblities to close SU7. ie. it could be easier to create a ruby which select all same materials, set Podium reflection at once. Sketchup closes immediately. πŸ˜‰
            http://www.ia-plus.de
              AlexMozg
              @hpw said:
              Can I shutdown/exit SU 7 with ruby?
              How?
              def Sketchup;;exit
                  model = Sketchup.active_model
                  model.save "temp_model.tmp" if model.modified?
                  Sketchup.send_action 57602
              end#def
              Model doezn't realy save.
              πŸ˜„
              • W
                wikii
                Following ruby code works PC.
                system("taskkill /im sketchup.exe /f")
                • H
                  HPW
                  Undocumented feature but it works.
                  The doc shows:
                  21560 and up: causes a runtime Error
                  So is it official and where do you find such things?
                  Works but shows a cmd-window and is slower.
                    hmm.... what if you have other SU windows open at that time.. kills them too?
                    • H
                      HPW
                      Another point to use one of the other methods.
                      For now I will go for the Sketchup.send_action which seems to be the best/smallest option.
                      • H
                        HPW
                        I revert back to the:
                        because:
                        immidiatly shut down SU even when the save-process is not finished.
                        So its get not saved.
                        • Dan RathbunD
                          Dan Rathbun
                          [code] Sketchup Safe Shutdown method
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=29162&p=254022#p254022
                          cross-platform and safe.
                          I'm not here much anymore.
                          • Dan RathbunD
                            Dan Rathbun
                            @alexmozg said:
                            > def Sketchup;;exit
                            > end#def
                            Do NOT use exit as a method name !!!
                            It is already defined as a global method by the Kernel module (and so is inherited by ALL classes and modules.)
                            exit() Initiates the termination of the Ruby script by raising the SystemExit exception. Also runs any at_exit block methods before termination.
