    Construction advice please: RSJ's
    5 Posts 3 Posters 427 Views 3 Watching
      andyc
      Hi Guys - help please! Found myself out-of-my-depth (AGAIN!!) I need to draw up a steel frame for a platform. It will be constructed from 254mm x 146mm section RSJ's, supported on 100mm square section steel uprights. What is the (non-permanent) standard way of connecting RSJ's to form corner- and T-joints?? This is a temporary structure which needs to be built and de-rigged quickly, so I'm assuming some type of bolt fixing? Does anyone have a picture/sketch of the right way to do this??
      As ever, all help gratefully received πŸ˜„
      A.
        Rob D
        Hi Andy
        Using a 10mm end plate and 10mm toe plate is a very easy and fairly standard way to go. Use M20 Grade 8.8 bolts as shown at 70mm or 90mm spacing. Otherwise use 90x90x10 RSA or similar angle (RSA = Rolled steel angle).
        Hope that helps you out
        Kind regards
        Rob
          andyc
          Rob - that is a massive help to me -thanks so much. πŸ‘ πŸ‘
          Genuinely grateful - you've got me out of a real hole. 😎
          cheers,
          Andy.
            Rob D
            Perfect reply... That's it !
              Rob D
              Glad to be of help πŸ˜„
