    Disappearing objects issue
    30 Posts 6 Posters 7.6k Views 6 Watching
    • Chris FullmerC Offline
      post removed pending further testing πŸ˜„
      All my Plugins I've written
        ok, I've been playing with the winniebz-1 model. Its possessed. Definitely something to do with the scale of the model, and the model's internal scale. No way to access that though. It feels like there is a tiny piece of hidden geometry miles away from poohbear, but I never could find anything like that. Perhaps copy and paste him into a clean model might help?
        Chris
          museummaker
          I looked at the possessed model, very strange.
          I exploded all groups, scaled him up by 100, went to purge and fix problems.
          Got this:? Not sure what it means.
          Maybe Poo is terminal?
          EDIT: He seems fixed after the above.
            Coronel
            This one is already a copy in a new document πŸ˜†
            I'm using now the document named "winnie2", my original backup. I fixed the scale problem but still It's driving me crazy with the intersections. Using bootools I'm getting weird results and sometimes SU is fixing the model.
            Each time I finish the intersection of a new group and try to do the next one it says the one or the second group is not a valid solid.
            Invalid? I'm invalid, not you, stupid bear! 😑
              mac1
              Chris
              Chris
              I tried copy to new SU and still had same problem, also hide the winne, selected all , then a delete to try and delete stray points but that did not work either., I think the key is when you explode the nested nose group and then scale the problem does not appear and this is some way related to the scale tool scales in relation to the grip and anchor and not the model its self so info for the basic model is retained some why hence the reset scale menu active.
              Note: You may notice when I did this with an incremental scale of .1 within the winnie context ( with nose exploded), then I would save then group again to see if problem came back. Doing this several times without the nose exploded the problem occurred and if you re-scale the huge model came back. Once the nose was exploded and a repeat of the process allowed me to scale all the may down to the ~75cm box level.
              I did the incremental approach because in my alleged mine I have the notion of reading somewhere the scale tool has a limit of 20 to .01 but have not been able to find this so this may have not been necessary.
                mac1
                coronel
                One more suggestion now that you have the scale problem fixed.
                Re-size your model up say maybe 500x, try your intersections at that size and then re-size back down when finished.
                Rational: 1)You did that the first time with the scale tool and it worked?; 2) There have been many postings about SU having problems with edges in the few mm range and maybe that is what is happening now and was previously.
                  It definitely sounds like a weird issue caused by tiny geometry. I ran a lot of tests on it and found it has 15 edges that come in at ~0.0mm. I delete all those, but the problem still persisted. So it looks like scaling way up ius the best solution. Its quite odd though.
                  Chris
                    Coronel
                    1. Yes I did it that way with the faulty docs before the problem begins.
                    2. Now I made a re-size using the tape method and after some attempts I finally could intersect the last arm, leg, and face but I was getting some opened faces that I need to close manually. Here it is:
                    Now is time to triangulate the model and try the sculpture tools plugin to polish the shape
                    winnie.skp
                      mac1
                      See you still have problems with the two eyes and nose. Suggest the following sequence, this could have been done back on your orginal winnie.skp model. Select the eye(nose)=>explode=>immediately then make it a group. After this operation( for each group) you will notice the re-set scale menu is grayed out for that group. This effectively brings the scale of these components to the level of the rest of your model vs presently really small so when you double click them things do not get weird. Tried this on your original posted winnie.skp model and it works! So on your original model you would go through this sequence, then do your re-size, I did this by drawing a line ref to the top of winnie's head, them used the tape tool, repeat the above sequence to bring the groups to the model ref size and you should be good to go. πŸ˜„. It looks to me this sequence results in the edges for the arms etc being much better behaved?
                        Coronel
                        You are right mac1
                        Geometry is not my priority at this moment as I told you in my PM. I will try different possibilities to give the model a natural look before the final render in SU.
                        Thank you very much, I'm impressed by the help received from the forum.
                        • 2 / 2
