    Texturing Plane Alpha bug?
    4 Posts 3 Posters 430 Views 3 Watching
    • E
      e-anima
      i textured a plane with a texture map that has an alpha. Frome one side of the plane it looks ok but drom the other side i can kind of XRAY through my model. (see image)
      The image shows the plane from both sides. I marked the area where i can see through the plane and through the roof ... i see the wireframe of the entrance through the geometry....this is..never seen such kind of behavior in any 3d app.
      Any ideas?
      Thank you
      Marco
      • thomthomT
        Try to adjust the Transparency quality in the Styles window.
        • GaieusG
          Also apply the transparent image on the other (back) side of the face. It will be applied mirrored so no further adjustment is needed.
          If it doesn't seem o fix the problem, group i8t separately (or if it is already, explode the group).
          This is (more exactly was, in SU 6) a known glitch but only with GE exports. BTW are you by any chance not using any of those "sketchy styles"? (I can't tell from the images)
          • E
            e-anima
            yea thats it. thank you
