    Resizing components.
    4 Posts 3 Posters 592 Views 3 Watching
    • R
      RodWall
      Hi All. New to the wonderful world of sketchup and am having many sleepless nights learning as fast as I can. I have run into a problem though. I cannot for the life of me change 1 dimension in a component. I have created a component that I need to resize the height frequently as I add it to a design. Scale changes all dimensions....?
      • numbthumbN
        numbthumb
        Hi and welcome!
        That shouldn´t be a problem. You did select it, and then hit "S"?
        Just do what it says - select a grip and move it to the scale.
        Comfortably numb...
        • R
          RodWall
          Thanks. Next question if you don't mind. Scale shows as a size of the original scale. 1:2 etc. Anyway I can type in a size ie: 2600mm...?
          • A
            Aerilius
            simply: yes
            You can do that with nearly all tools in Sketchup. Try it for the move tool: Select an object, move it while holding down ie. the left arrow key. After dropping it, type in "2m", enter, and then "5x", enter.
