    Cedar Shake Siding
    5 Posts 4 Posters 741 Views 4 Watching
      smokinbakin
      Does anyone with experience with this sort of stuff know how much of an 18" inch cedar shake panel should be exposed?
      Thanks for the Help
      "Set your goals low, and hope you don't get lower"
        I think about 1/3 of the shake should be exposed.
        • W Offline
          watkins
          This might be useful:
          http://www.extremehowto.com/xh/article.asp?article_id=60506
          Regards,
          Bob
          • DanielD Offline
            Daniel
            It depends on if they are used for roofing or for siding, and if the later if they are single or double course.
            For siding:
            Length...........single course........double course
            16 inch..........6 to 7-1/2"..........8 to 12"
            18 inch..........6 to 8-1/2"..........9 to 14"
            24 inch..........8 to 11-1/2".........12 to 20"
            If your talking about pre-assembled strips, the manufacturer will have an exposure range, but typically a 18"x96" strip would have about 7-1/2" exposure.
            For roofing, depends on the shake label (1, 2, or 3) and the roof slope.
            My avatar is an anachronism.
              smokinbakin
              Thanks, this really helps.
