    Need good Ruby scripter
    12 Posts 5 Posters 1.0k Views 5 Watching
    • T
      totom
      Hi all,
      I'm looking for someone who could create an automatic color material changer and Hi Res PNG exporter.
      Please, let me know if someone is interested and I'll explain the whole process
      Tom
      • Chris FullmerC
        I PM'ed you about it. I'm interested. If it is just changing material colors and exporting .png's, it shouldn't be too much of a "process" hopefully 😄
        Chris
        All my Plugins I've written
        • T
          totom
          Hello Chris,
          I send you a couple of PM but no answers..
          People, I still need somebody !
          • R
            RickW
            Have you tried SceneExporterPro for exporting your image files?
            RickW
            www.smustard.com
            • T
              totom
              Hi, It is more complex than that 😄
              Thanks for your try..
              @All : When I send a PM, it stays in the OUTBOX for hours.. is that a normal behavior ?
              @TIG : PM send ... but in Outbox.. should be yours soon...
              • J
                Jim
                Yes, it stays in the outbox until the person reads the message.
                Is there a difference between a .png and a Hi Res .png?
                • T
                  totom
                  Thanks Jim. I understand...
                  About the PNG and HI RES, No there isn't.
                  The Hi Res is bigger than the screen resolution like 8000x4000 px for instance
                  • thomthomT
                    Can your scene be exported in that resolution with the SU exporter?
                    Don't think you can make an alternative with ruby. The PNG is non-trivial, it'd require knowledge of the PNG format. But the ultimate show stopper would be that you can not read the 2D scene view with the ruby API.
                    • Chris FullmerC
                      You can do all image exports using view.write_image
                      Error 404 (Not Found)!!1
                      (code.google.com)
                      It should let you do a high-res .png just fine.
                      Chris
                      • thomthomT
                        (code.google.com)
                        Chris
                        That do the same thing the File->Export 2D does. 4000x8000 is pushing it, depending on the model. If SU's export fail then .write_image will fail as well.
                        • Chris FullmerC
                          @thomthom said:
                          That does the same thing the File->Export 2D does. 4000x8000 is pushing it, depending on the model. If SU's export fail then .write_image will fail as well.
                          Agreed, some models won't survive that resolution.
                          • thomthomT
                            Though, for these border cases, I have found that restarting SU help. Probably frees up a little extra memory. And some times I have more luck by exporting to BMP. I assume BMP works better because it's uncompressed so less processing is required.
