    [Plugin] Scale2Face.rb
    27 Posts 10 Posters 45.3k Views 10 Watching
      At long last version v1.2 is now available.
      Link: http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
      It Scales any Selected Component-instances/Groups up in Z to Selected Faces above them. It works for curved Surfaces, but remember that it Scales to all Selected Faces... so if you select a horizontal cylinder its whole curved Face gets Selected (which is actually Face facets) and therefore it Scales to the lower [nearer] Faces and then the upper Faces - if you want to Scale to just the lower [nearer] Faces you must first switch on Hidden Geometry and them Select just the lower Face facets required and it then Scales things just to those...
      Feedback please
      • olisheaO Offline
        olishea
        nice plugin, thank you
        oli
          rv1974
          Tig it doesn't work within groups 😒
          And maybe clicking 3 points instead of face would be better solution?
          Thank you (I mean it!)
            Here's a Ruby that'll do it [please change the original post's title to [Plugin]...]
            . scale2face.rb
            Usage:
            Select face(s) & group/component-instance(s) located below face(s).
            Unacceptable selections produce error dialogs.
            Pick 'Scale2Face' off the Plugins Menu
            or type scale2face in the Ruby Console.
            The selected items will be
            scaled upwards [in the Z] until their CLs meet the face or faces.
            Any intermediate faces etc are ignored; the scaling passes through them.
            It has a one step un-do.
            To Do: Alternative orientations to just the UP in Z.
            E.G. down and in XY
            Version: 1.0 20090717 First Release.
            1.1 20090721 Tweaked to avoid height glitches.
            1.2 20090811 Multi-face support added. Error msgs disabled.
            1.3 20090819 Now works within groups/component edits.
            Put in Plugins Folder...PayPalButton
              It does work inside groups etc now !
              See here for v1.3 http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
              Easy fix ray[1] .last gives face if in group/component edit mode... πŸ˜„ πŸ€“ πŸ€“
              • X Offline
                xrok1
                don't know how i missed this one 😳
                Thankyou! πŸ˜„
                β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                • X Offline
                  xrok1
                  @j_forrester said:
                  Great Plugin btw,
                  Just wondered if there are any developments of a version that takes into account a sloped surface instead of a flat plane?
                  Many thanks
                  it would be awsome if the scaled face matched the shape/angle of the scaled to face. any plans?
                  http://twilightrender.com/phpBB3/images/smilies/think.gif
                  • 2 / 2
