    [Plugin] Scale2Face.rb
    27 Posts 10 Posters 45.3k Views 10 Watching
      su30
      @tig said:
      Very busy - maybe next week ? 😐
      Sure TIG, in no hurry πŸ˜„
      su30
        j_forrester
        Great Plugin btw,
        Just wondered if there are any developments of a version that takes into account a sloped surface instead of a flat plane?
        Many thanks
        • utilerU Offline
          utiler
          @j_forrester said:
          Great Plugin btw,
          Many thanks
          Ditto.
          I think this would be neat!!!
          Just Curious...
            j_forrester
            TIG,
            Tried and tested.
            Works absolutely perfect! Many thanks this will be a great help.
              At long last version v1.2 is now available.
              Link: http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
              It Scales any Selected Component-instances/Groups up in Z to Selected Faces above them. It works for curved Surfaces, but remember that it Scales to all Selected Faces... so if you select a horizontal cylinder its whole curved Face gets Selected (which is actually Face facets) and therefore it Scales to the lower [nearer] Faces and then the upper Faces - if you want to Scale to just the lower [nearer] Faces you must first switch on Hidden Geometry and them Select just the lower Face facets required and it then Scales things just to those...
              Feedback please
              • olisheaO Offline
                olishea
                nice plugin, thank you
                oli
                  rv1974
                  Tig it doesn't work within groups 😒
                  And maybe clicking 3 points instead of face would be better solution?
                  Thank you (I mean it!)
                    Here's a Ruby that'll do it [please change the original post's title to [Plugin]...]
                    . scale2face.rb
                    Usage:
                    Select face(s) & group/component-instance(s) located below face(s).
                    Unacceptable selections produce error dialogs.
                    Pick 'Scale2Face' off the Plugins Menu
                    or type scale2face in the Ruby Console.
                    The selected items will be
                    scaled upwards [in the Z] until their CLs meet the face or faces.
                    Any intermediate faces etc are ignored; the scaling passes through them.
                    It has a one step un-do.
                    To Do: Alternative orientations to just the UP in Z.
                    E.G. down and in XY
                    Version: 1.0 20090717 First Release.
                    1.1 20090721 Tweaked to avoid height glitches.
                    1.2 20090811 Multi-face support added. Error msgs disabled.
                    1.3 20090819 Now works within groups/component edits.
                    Put in Plugins Folder...PayPalButton
                      It does work inside groups etc now !
                      See here for v1.3 http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
                      Easy fix ray[1] .last gives face if in group/component edit mode... πŸ˜„ πŸ€“ πŸ€“
                      • X Offline
                        xrok1
                        don't know how i missed this one 😳
                        Thankyou! πŸ˜„
                        • X Offline
                          xrok1
                          @j_forrester said:
                          Great Plugin btw,
                          Many thanks
                          it would be awsome if the scaled face matched the shape/angle of the scaled to face. any plans?
                          http://twilightrender.com/phpBB3/images/smilies/think.gif
                          • 2 / 2
