    Sketchup and vue exstream problem
    extensions
    4 Posts 3 Posters 778 Views 3 Watching
    • G Offline
      GGSardigna
      Hello!
      I have a problem with the rotation of materials vue.
      I created a model with sketchup, I exported the model as an object with its texture.
      The problem is when I go to rotate the materials that I imported with the model: the non-rotating. in 'preview pannel advanced editor "material wheel but when I go to render I can not see the rotation. I tried to save the imported material as the material of view, but does not work
      Some help?
      Thank you all!
        bubbalove
        You might want to go here: http://forums.sketchucation.com/viewtopic.php?f=80&t=18355&start=75
        It will receive more attention...
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
        • soloS Offline
          solo
          John
          I am not sure what you are saying, you have a model with a texture that imported fine into Vue and now you want to adjust the texture by rotating it?
          Firstly why not rotate it in SU before export?
          Secondly, how is your texture in Vue? is it bicubic?, world standard? faces?, there are so many setting options that need to be set that I can understand things going wrong.
          Please post an image if you would as it will make things easier as well as a screen shot of the material editor, I am sure we can solve this quick.
          http://www.solos-art.com
          • G Offline
            GGSardigna
            Thanks for the answers
            So I created a model with SU to which I applied the texture, go exported the model as a obj with texture coordinates.
            http://img219.imageshack.us/img219/8697/44852299.th.jpg
            when I go to rotate the texture, they do not rotate, I intend to rotate the preview of the advanced material editor but not in the render.
            http://img219.imageshack.us/img219/8169/64036861.th.jpg
            http://img219.imageshack.us/img219/2905/35123313.th.jpg
            sorry for my bad English
            Best Regards
            Jhon
