Sketchup and vue exstream problem
Hello!
I have a problem with the rotation of materials vue.
I created a model with sketchup, I exported the model as an object with its texture.
The problem is when I go to rotate the materials that I imported with the model: the non-rotating. in 'preview pannel advanced editor "material wheel but when I go to render I can not see the rotation. I tried to save the imported material as the material of view, but does not work
Some help?
Thank you all! -
You might want to go here: http://forums.sketchucation.com/viewtopic.php?f=80&t=18355&start=75
It will receive more attention... -
John
I am not sure what you are saying, you have a model with a texture that imported fine into Vue and now you want to adjust the texture by rotating it?
Firstly why not rotate it in SU before export?
Secondly, how is your texture in Vue? is it bicubic?, world standard? faces?, there are so many setting options that need to be set that I can understand things going wrong.
Please post an image if you would as it will make things easier as well as a screen shot of the material editor, I am sure we can solve this quick.
Thanks for the answers
So I created a model with SU to which I applied the texture, go exported the model as a obj with texture coordinates.
when I go to rotate the texture, they do not rotate, I intend to rotate the preview of the advanced material editor but not in the render.
sorry for my bad English
Best Regards
Jhon
