    Particle FX preview
    46 Posts 12 Posters 5.6k Views 12 Watching
    • P Offline
      phy
      I'm running
      1.8 ghz. AMD
      512 MB. ram
      212(something like that)MB NVIDIA
      But I have XP so it runs fast.
      it might be sketchup or another plugin.
      Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
        Sgt.A.Johnson
        Im running vista on a laptop with: 2ghz single core pentium celeron, 3gb RAM, 358MB Mobile Intel 965 Express Chipset. overall windows experience=3.1 on graphics. gaming graphics 3.3, processor 4.2, RAM 4.5, hard disk 5.2
        • W Offline
          Wacov
          Uhh, I need the FPS 😄
          Anyway, from the looks of it, only Jav is having a problem (sorry mate). The particle system should work fine for most users!
            JaViXP
            It is just wierd, I can run any SP model at more than 50 FPS and I run this one at less than 10 Frames Per Second. Also, the first time I play it, it is about 10 FPS, the seconds it is 5 FPS, then it is 2 FPS... It is slower 😲
            "Giving up is way harder than trying"
            JaViXP's Rendering
              CPhillips
              Open up the ruby console and see if it is printing any errors.
              • P Offline
                Physicsguy1
                Can't post my fps! All I get is a constantly-generating "Webdialog is still dirty!"...
                • P Offline
                  phy
                  This error is caused by changing something in the UI and exiting before clicking (anywhere on the screen). Click somewhere and then X out.
                  Download and try again.
                    JaViXP
                    It says something of 'warning'. I have just made a video of it.
                    Also, I get this (first time):
                    Inspecting model for errors
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae9b8c0>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae80dd0>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae6d138>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae593c8>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae45b08>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae32230>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae24328>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae1af38>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae0dfc0>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xae04ba0>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xadf7bf8>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xadee7a8>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xade5340>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xadce3d8>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xadbab60>
                    #<MSketchyPhysics3;;SP3xBodyContext;0xada72d0>
                    initializing joint controllers
                    ["Time", 1.815, "Frames", 20, "Fps", 11.0192837465565]
                    Note: Not exploding barrels
                    Video
                    JaViXP's Rendering
                    • P Offline
                      phy
                      Nothing unusual there, I'm getting the same stuff.
                        JaViXP
                        What about this? 😕
                        (eval);6; warning; already initialized constant ParticleStruct
                        JaViXP's Rendering
                        • P Offline
                          phy
                          @javixp said:
                          What about this? 😕
                          I get that too. I don't know what could be wrong. 😕
                          • W Offline
                            Wacov
                            ParticleStruct is the way I could attach variables to the particles. I guess it's not being removed between simulations, so when it's re-initialized in onstart, the sim throws up an error; it shouldn't affect the model.
                              Aerilius
                              I could imagine that it will have great realism, when you apply a radial png texture to the round faces.
                              Just like this one:
                              • W Offline
                                Wacov
                                SU has problems display textured transparency, and it'd be hard to position the texture. Plus, they're actually simple spheres 😄
                                  Aerilius
                                  Ok, I thought it would be "face camera" circle components. But maybe it would be worth a try to replace the spheres by other geometry. The plugin has really great possibilities!
                                  • P Offline
                                    Physicsguy1
                                    Wacov, I'm not sure you have already devised this but I want to make sure. Can you code it to have the effects originate at a determined Point3D? Or code it so you can do something like this: SetEffect('smoke',[0,0,0])?
                                    • W Offline
                                      Wacov
                                      The code in the demo lets you choose where you place it, among other things. Once I get the final thing done, it'll be:
                                      createParticle([0,100,100])
                                      Giving only a position will create a construction point. Giving a position and radius will create the default black smoke, and you'll also be able to copy a custom group, or (maybe) choose between a few presets. You'll have the option to make your own update code for the particles, which will be executed along with the normal code.
                                      • P Offline
                                        Physicsguy1
                                        could you possible have a direction for smoke and such? Like this createParticle([0,0,0],[10,10,10])
                                        • W Offline
                                          Wacov
                                          If you mean give it a velocity, sure, that's shown in the demo. Once I get the custom update working, you'll be able to make them do pretty much whatever you want 😍
                                            JaViXP
                                            Can you increase my FPS then? 😄
                                            It sounds pretty cool. Can you upload another .skp model to see if it runs faster?
                                            JaViXP's Rendering
                                            • 2 / 3
