    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 476 Posters 3.9m Views 476 Watching
    • boofredlayB Offline
      boofredlay
      This is absolutely beautiful, thank you.
      • urgenU Offline
        urgen
        ...cool! ๐Ÿ‘
        --pupil forever...------
        • W Offline
          watkins
          Dear Fredo,
          This is how it's done in Inventor
          and variable
          Kind regards,
          Bob
          • ely862meE Offline
            ely862me
            ๐Ÿ˜ฒ
            Another masterpiece!!Works like a charm!
            Thank you very much!
            Elisei
            Elisei (sketchupper)
            Come and See EliseiDesign
            • fredo6F Offline
              fredo6
              @watkins said:
              Dear Fredo,
              and variable
              Kind regards,
              Bob
              Apparently Inventor does just fillet, whether fix or variable offset. I have not seen the 3-direction rounding of corners. And the profile seems to be always an arc of circle.
                remus
                What a nice surprise ๐Ÿ˜„ Once again, thank you fredo, your hard work is always appreciated.
                • ely862meE Offline
                  ely862me
                  only one small thing .. when making this fillet some holes becomes filled ..can this be fixed ?
                  • fredo6F Offline
                    fredo6
                    Actually, it is Sketchup that automatically generate the faces. RoundCorner algorithm does not 'see' them.
                    I need to see if I can do something, but no guarantee!
                    • PixeroP Offline
                      Pixero
                      It would be great if the round corner could be turned off and just turn it on before render.
                      • W Offline
                        watkins
                        Fredo,
                        This gives more details on the fillet and chamfer options for Inventor
                        http://www2.ivcc.edu/perez/Placed%20Features.pdf
                        Regards,
                        Bob
                        • W Offline
                          watkins
                          Dear Fredo,
                          I forgot to say that I think you are absolutely brilliant! Thank you for all your hard work in not only writing these scripts, but documenting them so well. You really are a very generous chap.
                          Kind regards,
                          Bob
                          • fredo6F Offline
                            fredo6
                            @watkins said:
                            Fredo,
                            Regards,
                            Bob
                            Thanks. Interesting, but my first reaction would be that I understand why some of you prefer Sketchup, which is so much natural to use for this type of shapes (except maybe for the variable radius filleting).
                            Fredo
                            • W Offline
                              watkins
                              For the mechanically minded, RoundCorner is just perfect for all those radiussed and chamfered features. Setting the offset equal to the radius on the end of a pin will round the end of the pin beautifully.
                              Using RoundCorner.skp
                              • Bob JamesB Offline
                                Bob James
                                Just loaded this plugin for the first time. I drew a circle and, using the default parameters, clicked to proceed and got this ๐Ÿ˜ฎ
                                Not sure what it is, but it sure neat ๐Ÿ˜‰ Black hole generator maybe. ๐Ÿ’ญ
                                Now on to more serious testing. ๐Ÿ˜Ž
                                • Jean-FrancoJ Offline
                                  Jean-Franco
                                  you have to change the default parameter (1000mm) to a smaller value or draw a bigger circle.
                                  Jean-Franco
                                    Bob James
                                    Yes, I knew that but just wanted to see what would happen with the randomly sized circle I drew. ๐Ÿ˜„
                                    Still a fascinating result!
                                    • fredo6F Offline
                                      fredo6
                                      Actually creating black holes and big bang effects was the primary goal of the plugin. It is just a side effect that it sometimes round edges and corners, but promised, I'll fix this inconvenience:D ๐Ÿ˜„
                                        Bob James
                                        Fix it? FIX IT??? It's perfect already ๐Ÿคฃ
                                          ddcddc
                                          This is great stuff! thank you so much for your effort!
                                            Jim
                                            Another outstanding plugin, thank you. I was especially amazed at your brilliant and innovative use of openGL for the toolbar - it opens another world of possibilities I had never considered... who needs WebDialogs? ๐Ÿ˜†
                                            • 6
                                            • 74
                                            • 75
                                            • 4 / 75
