    Uninitialized constant
    12 Posts 3 Posters 2.6k Views 3 Watching
    • K
      Kapoue
      Hello,
      I'm trying to use rexml to read an XML file so I have downloaded rexml
      and I use this:
      require 'rexml/parsers/pullparser.rb'
      if I doing a mistake in the file name sketchup throw an error and with
      this line I don't have an error so I suppose that the file is loaded
      and my $PATH is ok.
      But when I try this:
      @xml = REXML::Parsers::PullParser.new( f )
      He said: uninitialized constant REXML::Parsers
      How can I resolve that?
      Thanks in advance
      Benjamin
      Here is my code
      ` require 'sketchup.rb'
      path=Sketchup.find_support_file("Plugins")
      Sketchup::require path+'/rexml/parsers/pullparser.rb'
      puts(path+'/rexml/parsers/pullparser.rb')
      class LDDFileImport
          # Initialize variables
          @model = Sketchup.active_model
          # function to  debug easilly
          def DebugPuts(message)
            if $show_debug_LDD_messages == true
                  puts(message)
          #load XML
          def ParseFile( filename )
                  DebugPuts("Begin ParseFile")
                  if (filename == nil) then return nil; end
                  model.start_operation "Import LDD File"
                  begin
                    DebugPuts "Parsing: "+ filename
                    entities = model.active_entities
                    f = File.new( filename, 'r' )
                    begin
                          model.selection.clear
                          #model.selection.add TopLevel(entities)
                    ensure
                          f.close
                    model.commit_operation
                  rescue => bang
                    if (model)
                          model.abort_operation
                    UI.messagebox( "Error (in script) while reading \"" + filename +
      "":\n" + bang )
      Quick Debug Code, can be called by the ruby console
      def lddParserTest()
      was = $svgImportScriptDebug
      begin
      $show_debug_LDD_messages = true
      f = LDDFileImport.new()
      f.ParseFile( 'C:/Users/Admin/Desktop/Lego/3pcslxfml.lxfml' )
      ensure
      $show_debug_LDD_messages = was
      def DoLDDImport
      filename = UI.openpanel "Import lxfml File",nil,"*.lxfml"
      if (filename)
      f.ParseFile( filename )
      Register within Sketchup
      if(file_loaded("ldd.rb"))
      menu = UI.menu("Plugins");
      menu.add_item("Import lxfml File...") { DoLDDImport() }
      file_loaded("ldd.rb")`
      • thomthomT
        It's possible you haven't required all the correct files.
        On a sidenote, REXML isn't the fastest XML parser as it turns out. Check out this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=20297
        • TIGT
          Try adding:
          Dir[path+'/rexml/parsers/'].each{|file|Sketchup::require file}
          This will load everything in that directory in case something else is missing...
          • thomthomT
            @tig said:
            Try adding:
            Or use the require_all call.
            • TIGT
              Duh!
              Something like...
              Sketchup::require_all 'path+"/rexml/*/*.rb"'
              Which would load all '.rb' rubies in the '/parsers/' folder AND those in any othersub-folders too...
              • thomthomT
                Don't think you need to prefix it with Sketchup::... I've only used it once, but I think I just used require_all.
                @tig said:
                AND those in any other sub-folders too...
                Really? I haven't found any other info on the method than this page: http://code.google.com/intl/nb/apis/sketchup/docs/loading.html
                • TIGT
                  I assumed the Sketchup:: was because it might get scrambled later ?
                  The * wildcards .../*/*.rb process all folders in the path, and require the .rb files found ?
                  • thomthomT
                    Ah,.. I don't know anything about scrambled files.
                    I found this though on the sub folder topic: http://forums.sketchucation.com/viewtopic.php?f=15&t=16029&p=124772#p125137
                    Maybe it does include subfolders.
                    If so I need to check CityGen's code as we use it there. I thought it only took the rb and rbs files in that folder - not going deeper. I actually think that for CG we don't want it doing that either.
                    Would have been nice is sub-folders where an optional argument...
                    • TIGT
                      We talk at cross-purposes 😳 - I didn't know Jim had made a require_all version...
                      I thought you meant this one that takes wildcards...tarcieri-require_all-ce01fef7205f87ade3c1e7bd626f0610f01cc013.zip the require_all.rb is in the /lib/ folder...
                      Since others might not have these perhaps the
                      based version is safest ?
                      • thomthomT
                        But require_all is a function bundled with SU: http://code.google.com/intl/nb/apis/sketchup/docs/loading.html
                        The sketchup.rb file defines a require_all function which requires all files with the extension .rb in a given folder.
                        Another good option for automatically loading Ruby scripts is to create your own folder of Ruby scripts (outside of the Plugins directory) and add that directory to the sketchup.rb file. For example, to load all scripts in the myrubyscriptsdirectory:
                        Question is, does these third-party solutions override the native method?
                        • thomthomT
                          That's a nice snippet.
                          Though, I have to see if this other version overwrites the built-in method. I think it can cause problems for CG if suddenly loads sub-folders.
                          • TIGT
                            Never knew require_all was built in... 😳
                            require_all("C:\myrubyscriptsdirectory\")
                            You then could easily use it to do subfolders thus:
                            Dir.foreach("C:\myrubyscriptsdirectory\"){|entry|require_all(entry)if FileTest.directory?(entry)}
