    Ado script
    6 Posts 3 Posters 668 Views 3 Watching
    • F Offline
      fabiorossi
      I got Su 6 Pro but when I try to export in 2D my skp file I cannot export in dwg format.......the only format to export are pdf, eps,bmp, jpg,tif, png,epx; why i cannot export in dwg format??
      my blog
      http://progettin3d.blogspot.com/
        remus
        If you use the 3d export instead you should have the option ot export dwg from there.
        • F Offline
          fabiorossi
          even if I use the 3d export option i can export in 3ds, obj,dae, kmz,xsi,fbx, vrl but no dwg!
          I've installed SU 6 Pro overwriting Su 6 free.......is this the error??
          my blog
          • Didier BurD Offline
            Didier Bur
            It seems you miss an exporter here. Check your "Exporters" folder for dll's related to dwg format, skp2acad.dll in particular.
            Hope this helps,
            DB
            • F Offline
              fabiorossi
              yes, I've that exporter folder, skp2cad.dll.....................!!
              my blog
              • F Offline
                fabiorossi
                .....I've the skp2acad.dll in the Exporters folder for dll's but however I cannot export in dwg format!
                my blog
