Ado script
I got Su 6 Pro but when I try to export in 2D my skp file I cannot export in dwg format.......the only format to export are pdf, eps,bmp, jpg,tif, png,epx; why i cannot export in dwg format??
If you use the 3d export instead you should have the option ot export dwg from there.
even if I use the 3d export option i can export in 3ds, obj,dae, kmz,xsi,fbx, vrl but no dwg!
I've installed SU 6 Pro overwriting Su 6 free.......is this the error?? -
It seems you miss an exporter here. Check your "Exporters" folder for dll's related to dwg format, skp2acad.dll in particular.
Hope this helps, -
yes, I've that exporter folder, skp2cad.dll.....................!!
.....I've the skp2acad.dll in the Exporters folder for dll's but however I cannot export in dwg format!
