    Real Filed of View
    4 Posts 4 Posters 492 Views 4 Watching
    • A
      arcano
      Hi to all!
      I need the value of a real field of view for my scenes in Sketchup7. The default value when I start sketchup is set to 35 degrees, but for me the scene are too flat.
      • R
        remus
        Select the zoom tool, type the filed of view you want, press enter πŸ‘
        • GaieusG
          If you just type the number (as Remus suggests), it will set the degree. You can also give the value in focal length if you type mm(millimetre) after the number.
          • thomthomT
            If you set the focal length in mm you will afterwards still set the focal length in mm. Doesn't seem to revert back. No in my experience anyway...
