    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 221.3k Views 76 Watching
      @kieran28 said:
      hope this doesn't sound stupid but does this plugin work on mac OS?
      Yes. πŸ˜’
      Most scripts as cross platform, they clearly say if they aren't...
      Make sure you are putting things into the MAC's HD path 'plugins' folder NOT the 'user' one, and extracting files preserving subfolders etc as clearly spelled out in the instructions...
      πŸ€“
      • I Offline
        isir1313
        hello:D im new at this and i would really like to use this pluggin! can anybody help me install it? THANNNKS in advanced:P
          This link gets you the ZIP file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 that includes ALL of my 'Extrusion' tools...
          If you are brave you can follow the link's instructions... and move the extracted files/subfolder_of_files into your 'Plugins' folder and restart Sketchup...
          If you are complete novice then may I suggest that you go here http://forums.sketchucation.com/viewtopic.php?p=375454#p375454 and firstly install the 'simple-installer' - its installation/use is very clearly explained in that thread - to install it use the Window > Preferences > Extensions > Install_Archive... button - selecting the tool's RBZ file...
          Once that's installed it and restarted Sketchup you can use it to install any scripts/zip/rbz/etc you might download... it beats using any brain cells... πŸ˜’
            sryu006
            Hi Thank you for your nice plugins..
            Don't know what's wrong with it but when I try to use 'ExtrudeEdgesByEdge' I'm keep getting 'Select 2 Groups of Edges ! ....' even I already have two grouped edges selected...
              Please post a simple example SKP that you can't get to work...
              We can then test it and see where you are going wrong...
              Remember that you must have two groups-of-edges.
              Those groups must both contain edges - they cannot be inside a subgroup or component-instance.
              The groups must be in the same 'context'.
              Only select the two groups, nothing else.
              They must be able to be extruded into a 3d form.
              So two 'flat' sets won't achieve much...
                Bua
                It is great, Thanks πŸ˜„ πŸ‘
                  chaleampol
                  thank you TIG
                    tkeepers
                    you sure this works for 2019?... the tool bar does not show up for me!
                      Yes. It works in SU2019.
                      Do you have the latest version installed? Is it enabled? Did you restart SketchUp to make sure it gets loaded?
                        You've probably posted in the old thread that relates to just this tool.
                        The various 'EEby' tools were merged long ago into the "Extrusion Tools"...
                        It works in all current versions of SketchUp - including v2020, although its guidance notes currently stop at v2019. Since v2017 it has become more prone to Bugsplats during very complex modeling operations, so "always-save-before-using"...
                        Get the RBZ from here and install it...
                        https://sketchucation.com/pluginstore?pln=ExtrudeTools
                        As DaveR says you should then see the 'signed' entry in the Extension Manager as 'ExtrudeTools' [TIG], and the toolbar can be activated, there are also menu entries...
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 10 / 10
