    Curved surface
    5 Posts 4 Posters 579 Views 4 Watching
    • B
      barrington
      I am trying to create a curved surface but am having a little fifficulty with the curved section as per my attachment, and would be grateful for some assistance
      Curved surface.skp
      • Chris FullmerC
        Here is a quick video that shows how you could do it. Note that I am testing some things and when they don't work how I want, I hit ctrl-z for undo quite a few times. So when geometry quickly re-appears on the screen, that is why.
        Also, your geometry was different on each end of the object. So it was a little trickier than necessary (hence all the undos). Anyhow, hope it helps,
        (no sound)
        [flash=626,594:3nhwl0k5]http://www.chrisfullmer.com/chrisfullmer/forums/curvymaker.swf[/flash:3nhwl0k5]
        Chris
        All my Plugins I've written
        • D
          d12dozr
          Try this tutorial, but Chris's answer is probably better
          Curved surface Tut.skp
          http://goo.gl/f7ooYh
          • B
            barrington
            Thank you so much for the help, really not so hard when you can do it πŸ˜‰
            • Jean LemireJ
              Jean Lemire
              Hi Barrington, hi folks.
              Or try this one if the object has some symmetry.
              Curved surface.skp
