    Milli-second timer?
    10 Posts 4 Posters 508 Views 4 Watching
      Jim
      I found out UI.start_timer has a one-second resolution, so is there some way to implement a milli-second timer in Ruby without pausing execution?
      Threads, maybe?
        Typing 0.1 seem to work... ...or is there some issues I'm not seeing?
          Jim
          start_timer will accept a value less than a second - say 0.5, but it returns immediately, and doesn't wait for the 0.5 seconds.
            Ah, rounds down to an Integer? hmm...
              Get the Time and remember it, as say 'time'.
              Keep getting the Time in a 'while time < time+clicks' loop till 'time+clicks' exceeds expectations - or / milliseconds /seconds / minutes etc after initial 'time'...
              • Chris FullmerC Offline
                Yeah, I've found that my code like
                ` now = Time.now
                do lots of code here
                now2 = Time.now
                puts now2-now`
                That will return a time down to the 1/100 second on my system.
                All my Plugins I've written
                  But with that allow other code to run?
                    Jim
                    This is somewhat related, but I just found timeout.rb in the Ruby standard library.
                    With it, you can do this (abort a long-running operation) I have not tried too hard to break it, but it appears to work well. SketchUp still 'white-screens', but it does abort after the set time (20 seconds in this example)
                    begin
                      timeout(20) do
                        Sketchup.active_model.start_operation "Draw Sphere"
                        up = Geom.linear_combination(0.5, Z_AXIS, 0.5, Y_AXIS)
                        entities.add_group.entities.add_sphere([500, 500, 0], 200, up, 24)
                        Sketchup.active_model.commit_operation
                    rescue TimeoutError
                      Sketchup.active_model.abort_operation
                      UI.messagebox("Operation Aborted - taking too long.")
                      Jim
                      Yeah, what wanted to do is detect a "double-click" in a method called from a shortcut. Single tap - method a gets called, double tap - method b gets called.
                      I can do it using Time.now - last_click_time, but method a always gets fired under both circumstances. I'm fairly sure I need a millisecond timer to delay the first call to method a in case a double-tap occurs.
                      Like maybe the normal single-tap runs the method, but a double-tap brings up a config dialog.
                        Jim
                        Oh yeah, I'm definitely going to try to tie this in to start_operation. That way, I can set a single timeout limit for all scripts transparently.
