    How do I precisely postion in 3 axes?
    5 Posts 3 Posters 541 Views 3 Watching
    • K
      Khai
      I'm probably being dense and missing this.
      I want to place an object precisely in 3 axes. for this question they are - x -.096 Z 1.678 and y -3.301 this matches up on another model I have in trueSpace thats just to large to import into Sketchup. my idea was that by matching the center point of this pipe's face I can then build the next section in Sketchup and export that out to tS.
      but, I can't seem to just enter the co-ordinates I need easily. is it really try and position this from the origin and move it axes by axes into place or can I just enter the 3 co-ord's in and bam I'm there?
      • R
        remus
        You can do it by putting in the co-ordinate you want:
        1. Select everything you want to move
        2. Pick the move tool and start the move from the point you want at your co-ordinates
        3. type [x coordinate,y coordinate,z coordinate] then press enter
        • K
          Khai
          told you I was being dense..
          thanks!
          • GaieusG
            What Remus says - if you are on an English keyboard (which I suppose as you are using dots as decimal separators). In your particular case (with your example) it would look:
            [-.096,-3.301,1.678]
            Note that the order is always x,y,z
            • K
              Khai
              thanks guys thats working πŸ˜„
              now I just have to account for differing Axes notation....
