    SU2Render2PP?
    4 Posts 3 Posters 668 Views 3 Watching
    • honoluludesktopH
      honoluludesktop
      It can be confusing when a SU beginners like myself see the work of others. I am beginning to believe that most, if not all the good Architectural illustrations shown here are the result of post processing. I am also beginning to believe that most renders are post processed.
      • R
        remus
        I think your right in your observations.
        Although it is possible to get presentation quality images straight from the renderer it can take a lot of tweaking. Most of the time it is far easier to get the render looking reasonable then clean it up in pp
        • thomthomT
          Yea.
          Some times we don't render the SU models. But still post-process in PS most of the times.
          And when we do render - we also post process. Post processing renders are pretty much a must. It takes cares of the final tweaks much quicker than re-rendering over and over again to get it right. You can also save time by inserting photo elements that would otherwise take ages to render - for instance vegetation.
          • honoluludesktopH
            honoluludesktop
            I haven't used post processing for landscape and other objects (yet). I do it primarily to adjust, brightness, contrast, and gamma.
