    Cutting (metal) extrusions
    7 Posts 4 Posters 1.3k Views 4 Watching
    • chrisglasierC Offline
      chrisglasier
      What, please, is the best way to "cut" a metal extrusion like this slice 60.png at say 60 degs?
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        remus
        Draw a rectangle, your 'cutting tool' if you will. Rotate it 60 degrees, move it to where you want the cut. Select the rectangle and the extrusion, right click->intersect->with selection, then delete the stuff you dont need.
          chrisglasier
          Bootiful thanks Chris
            try also Zorro2 by Whaat πŸ˜‰
            Sorry I don't remember The Cap Holes plug creator name and where to find it! 😳
            Very useful when you have some holes! β˜€
              chrisglasier
              Thanks to you and Whaat!
              If you are interested I'm making the structure for the roof intersection here (WIP)
              My problem is that in Thailand they use C section steel roof members, which makes the cuts "somewhaat" challenging for an old newbie like me.
              Toodle pip!
              Chris
              • H Offline
                Howard leslie
                Chris,
                I can highly reccomend that you purchase a copy of BoolTools.
                http://www.smustard.com/script/BoolTools
                Take a look at movie file.
                In your case use in Difference Mode.
                This will save you lots of messing about with intersecting and deleting.
                Although its possible this way,
                • it can get quite fiddly and tedious - especially if you've got lots of steel memnbers to do.
                  In your case you would draw a triangular solid block (the hole in your roof).
                  Use this block to trim off the protruding steel members that are visible and unwanted.
                  2-3 minutes max for the whole lot.
                  Regards
                  Howard L'
                  chrisglasier
                  ... 2-3 minutes max for the whole lot ...
                  Thanks Howard - very considerate
                  Chris
