    Texture size
    5 Posts 4 Posters 393 Views 4 Watching
      raduteo
      Hi all, is there a way to increase the maximum texture size? 1028 is really limiting.
      Thanks!
        troyhome
        It is limiting! as is the limits on the resolution of imported images- i guess in a way it's the same limit 😒
        IOviz.com
        SU Pro 2024 PC
          Thanks!
          The original limit is 1024. However, you can use "Maximum texture size" (2048 - the double of the "original") if you set it in Preferences > OpenGL settings (maybe this is Windows only however).
            dylan
            I can confirm this setting is also available on Mac
            http://dmdarchitecture.co.uk/
              πŸ‘
              Thanks, Dylan. I wasn't sure. Before SU 7 had this "improvement" and we used to be able to handle 1024 pixel images only, there was a "registry hack" to access 2028 pixel images but it was Windows only.
              Good to know it works on Macs now, too!
