    Podium Photomatch (AGAIN!) [TUTORIAL]
    31 Posts 14 Posters 7.1k Views 14 Watching
    • olisheaO Offline
      olishea
      good stuff, ill make a step by step tutorial for this next week
      oli
      • maxhouserocksM Offline
        maxhouserocks
        This is an old post, but i am hoping one of you fine gents might be able to steer me in the right direction. I have been looking for a quick way of rendering SketchUp PhotoMatch views within Sketchup via a rendering plugin. I cant find any that will SEE the PHOTOMATCH background. Any ideas of a package that will render everything together?
        I have been using this compositing method above also but want to avoid photoshopping if necessary to save time. These photomatches are the only thing i cant take care of in Lumion(really needs a photomatch feature), so its usually a quick, down and dirty thing...but i would like to do better, faster.
        I used to use Kerykythea alot, which will import the PHOTOMATCH if i remember correctly... its been a long time and im not sure i want to get back into Kerykythea since it has not been moving forward at all in development.
        I usually just end up exporting directly from sketchup, like this, but i would really like to render it even if its a so-so render solution for Sketchup...just to be able to get light and shadows, etc on photomatches.
        any advice welcome.
        Thanks,
        Bob
        rachristman.blogspot.com
        Sketchup export of photomatch
        Robert A. Christman
        http://rachristman.blogspot.com/
        • emerald15E Offline
          emerald15
          Oli, did you ever get a chance to make that tutorial - I'd be really interested. I've just recently started rendering my work (with Twilight Render) and need to fit models into photographic backgrounds quite often. I started with a similar technique of marking the model image & superimposing it into the background in photoshop. However, I couldn't get a good masked image (halo lines around objects).
          I then tried (now, my preferred method)- dropping the background image into SU as a watermark, positioning the models to fit into background, then setting the same background up in the Twilight environment setting. It hadn't occurred to me to match photo the background - good idea!
            seems you can also try the free Visualizer for obtain some transparent backgrounds ! ?
              emerald15
              Thanks Pilou. I'll definitely be trying that.
              • pbacotP Offline
                With Twilight did you try an alpha mask?
                • olisheaO Offline
                  olishea
                  The tutorial is in the first post of this thread....I didn't show every photoshop method though.
                  For masking you should really look at this tutorial. It really does make perfect masks. You can choose to mask more or less and completely eliminate halos. Don't be afraid to close stamp halos out either, there is nothing worse than white halos.
                  Masking Hair in Photoshop CS3
                  Masking hair is one of the harder challenges faced when you want to move a subject from one background to another. Here are two techniques for getting this done.
                  Layers Magazine (layersmagazine.com)
                  If you can mask hair you can mask anything.
                  Don't forget you can always select your mask in photoshop, then Select>Modify>Expand (or Contract)....you can nudge the mask by a pixel or two to crop the edge of the mask.
                  oli
                  • HornOxxH Offline
                    HornOxx
                    Hi Oli
                    Today I have seen your excellent example - a great and very accurate work and thank you for showing your "Making Of". The location of your building is great (the building itself as well of course!). This Medieval bridge (?) must be a great view for users of your building.
                    Since this surrounding is so interesting, it is not only correct but even necessary to use Photo Match here!
                    Since I've done a similar Making Of example a few days ago, I think your thread might be a good place for adding it here and I hope that´s ok? (In my case I used Shaderlight for rendering but the working principle is the same as using Twilight or Podium etc.)
                    Using a simple dummy scene, the attached pictures will show the steps which are necessary to make a simple interior exhibition simulation by using SketchUps “Photo Match”.
                    An added bonus of this example is, that the exhibition design should be reflected in the glossy reflecting floor of the exhibition hall.
                    For the result shown here, I have only used SketchUp and Shaderlight, no postprocessing in Photoshop - but only because this scenario was so simple of course.
                    I hope this Photo Match mini-tutorial is useful as well ...
                    Adjusting of the Perspective in PhotoMatch
                    ![Adding and "Photo Match"-Texturing of a Floor segment](/uploads/imported_attachments/tMkv_02.jpg "Adding and "Photo Match"-Texturing of a Floor segment")
                    Model Overview
                    Adjusting of the Material Properties within the used Render tool
                    Adjusting of the Light Properties within the used Render tool and Final Render
                    never trust a skinny cook
                      maxhouserocks
                      I think what i have been looking for is possible if a renderer allows the use of the custom background image, which most should. That way, the same image that was used for PHOTOMATCH can be used a background image and hopefully avoid the need for masking and comp'ing when doing quick photomatch exercises.
                      i am still on the look out for a quick render package that will just render the model and the photomatch photo natively.
                      Shaderlight looks interesting. Hope to test that out as a quick solution when not using Lumion.
                      Thanks guys!
                      Bob
                      Robert A. Christman
                      • olisheaO Offline
                        olishea
                        Nice tutorial and of course I do not mind HornOxx. 😄
                        Max, unfortunately some PP is required. You can use custom background environments in most render apps now, so maybe that's the way to go. You also need to "tell" the render app which is foreground and which is background (sometimes your photograph overlaps the building i.e. lampposts, cars, people etc....)
                        I don't think it will ever be as simple as "Match Photo, Project photo textures, Set materials, Render". There will always be a degree of photoshop to these types of images for the reasons mentioned above. Unless some render app introduces built-in custom masking which I doubt will happen.
                        The only other way of producing these images is taking your own spherical panorama and then insert your building into the context; real light, real materials, real reflections, real scale....but again, some foreground elements may need to be photoshopped in front of your building/subject. You also need a nodal ninja tripod (or equivalent) and DSLR camera which cost $$$$. Or you could borrow mine!
                        oli
                          maxhouserocks
                          Thanks Olishea. I always try to "draw over" when i can for things like foreground lamp posts, etc, as i did in the image posted at top (the outdoor seating area is new) but no matter what it seems you are correct... the better final product will always need to be rendered and comp'd in PS to get things just right. Excellent masking tutorial link, btw. thanks for sharing.
                          Robert A. Christman
                          • 2 / 2
