    Component names
    11 Posts 2 Posters 773 Views 2 Watching
    • chrisglasierC
      chrisglasier
      As you can see from this:
      I can retrieve the names of scenes and layers. I can also seem to do things with properties to save, views, and styles. Collections and groupings are something for later. But I can't get to grips with retrieving component names. For example, what is bed.skp all about here?
      path = Sketchup.find_support_file "Bed.skp", "Components/Components Sampler/" model = Sketchup.active_model definitions = model.definitions componentdefinition = definitions.load path name = componentdefinition.name
      I just want to make an array of each of the names that appear in the entity info box.
      Any help yet again gratefully received!
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
      • chrisglasierC
        chrisglasier
        @tig said:
        To do stuff on the model's content you need to ...
        Looks great; many thanks Chris
        • chrisglasierC
          chrisglasier
          Sorry one more bit of bother
          Chris
          • TIGT
            Sorry typo by me...
            insts=[];model.active_entities.each{|inst|insts.push(inst)if inst.typename=="ComponentInstance"}
            I usually use 'e' as my block variable BUT changed it to 'inst' to help you BUT forgot to change one !!! It's inst.typename... NOT e.typename... I've edited the original too...
            • TIGT
              To do stuff on the model's content you need to find the placed component instances...
              To find an instance's definition name use
              inst.definition.name
              , to find its individual instance name (you can also give each instance its own name using entity info...) you can use
              inst.name
              To do stuff on the model's data-base definitions etc use
              defns=model.definitions;defns.each{|defn|insts=defn.instances;insts.each{|inst|###etc###} }
              Again defn.name or inst.name to give you their names...
              You can also find an instance's unique enduring ID if needed...
              Groups work slightly differently... but similar enough...
              • chrisglasierC
                chrisglasier
                No sorry please! (Chinglish)
                Yes I thought that but thought maybe it was some special thing when I did not get the answer I was expecting with inst. I thought active_entities was the same as select all, but I see now it's not ... so I get all components rather than just those in the scene (like outliner does). If you have time to figure that out for me that would be great ...
                Chris
                • TIGT
                  model.selection
                  gives only currently selected entities
                  gives only entities that are currently 'active' i.e. editable - e.g. inside a group edit when you would want to ignore other external things
                  model.entities
                  gives all of the model's entities, even those currently not editable.
                  It is often best to use 'active_entities' as it is equal to 'entites' if you are currently at the base model level but it's limited to the edited instance-definition/group's entities if you are not. If you use 'entities' and were to add something to them it is put at the base level - and it might then be outside of the group edit and lead to confusion/splats, whereas with 'active_entities' it is put at the lowest level in that edit, also note that definition.entities or group.entities returns the specified definition's or group's entities etc...
                  I think in your case 'model.entities' is what you want ?
                  • chrisglasierC
                    chrisglasier
                    Ok thanks but it's not quite there yet I'm afraid, and this is of course a very important part of the whole.
                    If I select all from the edit menu, and then use model.selection instead of active_entities I can abstract just the instances that show in that scene (page). Is it possible to "ruby" the select all?
                    Chris
                    edit added pic
                    • TIGT
                      Use 'model.entities' and filter it thus ?
                      insts=[]
                      model.entities.each{|e|insts.push(e)if e.typename=="ComponentInstance"}
                      ### insts is then an array containing all of the instances in the model
                      ### you could also add names, groups etc
                      If you want only things that are active then use 'model.active_entities'.
                      I'm not sure you can get things only if they are visible in a scene ?
                      Do you mean not 'behind' the camera ?
                      You can of course get if they are hidden or on off-layers etc and remove them from the array...
                      • chrisglasierC
                        chrisglasier
                        That's it ... but of course?? I'll get back on it tomorrow. In the meantime thanks for your help.
                        Chris
                        • chrisglasierC
                          chrisglasier
                          Chris
                          Here's the result:
                          # Lists components and groups (with hidden status) in a scene
                          @dlg.add_action_callback("findComponents") {|d, p|
                          entities = model.active_entities
                          a = 0
                          array = []
                          entities.each do |entity|
                          if  entity.class == Sketchup;;Group || entity.class == Sketchup;;ComponentInstance
                          if entity.layer.visible?
                          array[a] = []
                          if  entity.class == Sketchup;;ComponentInstance
                          array[a][0] = entity.definition.name
                          array[a][0] = entity.name
                          array[a][1] = entity.hidden?
                          array[a] = array[a].join(",")
                          a+=1
                          end  #if class
                          end  # if visible
                          end  #loop
                          array = array.join(";")
                          cmd = "receiveComponents('#{array}');"
                          @dlg.execute_script (cmd)      }
                          Showing scene, aspect and component lists - 3 column,19 row nameset display
                          Tally ho!
                          Chris
