    Component names
    11 Posts 2 Posters 774 Views 2 Watching
    • chrisglasierC
      chrisglasier
      @tig said:
      To do stuff on the model's content you need to ...
      Looks great; many thanks Chris
      • chrisglasierC
        chrisglasier
        Sorry one more bit of bother
          Sorry typo by me...
          insts=[];model.active_entities.each{|inst|insts.push(inst)if inst.typename=="ComponentInstance"}
          I usually use 'e' as my block variable BUT changed it to 'inst' to help you BUT forgot to change one !!! It's inst.typename... NOT e.typename... I've edited the original too...
            To do stuff on the model's content you need to find the placed component instances...
            To find an instance's definition name use
            inst.definition.name
            , to find its individual instance name (you can also give each instance its own name using entity info...) you can use
            inst.name
            To do stuff on the model's data-base definitions etc use
            defns=model.definitions;defns.each{|defn|insts=defn.instances;insts.each{|inst|###etc###} }
            Again defn.name or inst.name to give you their names...
            You can also find an instance's unique enduring ID if needed...
            Groups work slightly differently... but similar enough...
            • chrisglasierC
              chrisglasier
              No sorry please! (Chinglish)
              Yes I thought that but thought maybe it was some special thing when I did not get the answer I was expecting with inst. I thought active_entities was the same as select all, but I see now it's not ... so I get all components rather than just those in the scene (like outliner does). If you have time to figure that out for me that would be great ...
                model.selection
                gives only currently selected entities
                gives only entities that are currently 'active' i.e. editable - e.g. inside a group edit when you would want to ignore other external things
                model.entities
                gives all of the model's entities, even those currently not editable.
                It is often best to use 'active_entities' as it is equal to 'entites' if you are currently at the base model level but it's limited to the edited instance-definition/group's entities if you are not. If you use 'entities' and were to add something to them it is put at the base level - and it might then be outside of the group edit and lead to confusion/splats, whereas with 'active_entities' it is put at the lowest level in that edit, also note that definition.entities or group.entities returns the specified definition's or group's entities etc...
                I think in your case 'model.entities' is what you want ?
                • chrisglasierC
                  chrisglasier
                  Ok thanks but it's not quite there yet I'm afraid, and this is of course a very important part of the whole.
                  If I select all from the edit menu, and then use model.selection instead of active_entities I can abstract just the instances that show in that scene (page). Is it possible to "ruby" the select all?
                  edit added pic
                    Use 'model.entities' and filter it thus ?
                    insts=[]
                    model.entities.each{|e|insts.push(e)if e.typename=="ComponentInstance"}
                    ### insts is then an array containing all of the instances in the model
                    ### you could also add names, groups etc
                    If you want only things that are active then use 'model.active_entities'.
                    I'm not sure you can get things only if they are visible in a scene ?
                    Do you mean not 'behind' the camera ?
                    You can of course get if they are hidden or on off-layers etc and remove them from the array...
                    • chrisglasierC
                      chrisglasier
                      That's it ... but of course?? I'll get back on it tomorrow. In the meantime thanks for your help.
                      • chrisglasierC
                        chrisglasier
                        Here's the result:
                        # Lists components and groups (with hidden status) in a scene
                        @dlg.add_action_callback("findComponents") {|d, p|
                        model = Sketchup.active_model
                        entities = model.active_entities
                        a = 0
                        array = []
                        entities.each do |entity|
                        if  entity.class == Sketchup;;Group || entity.class == Sketchup;;ComponentInstance
                        if entity.layer.visible?
                        array[a] = []
                        if  entity.class == Sketchup;;ComponentInstance
                        array[a][0] = entity.definition.name
                        array[a][0] = entity.name
                        array[a][1] = entity.hidden?
                        array[a] = array[a].join(",")
                        a+=1
                        end  #if class
                        end  # if visible
                        end  #loop
                        array = array.join(";")
                        cmd = "receiveComponents('#{array}');"
                        @dlg.execute_script (cmd)      }
                        Showing scene, aspect and component lists - 3 column,19 row nameset display
                        Tally ho!
