    Automating export of scenes
    6 Posts 3 Posters 743 Views 3 Watching
    • chrisglasierC Offline
      chrisglasier
      I had a look at this thread. As Allan wrote: "there has to be a better way?" Anyone know of one?
      The reason I need it is described here and here
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        chrisglasier
        Thanks again TIG. I will try it out tomorrow as it's time for dinner hereabouts. Did you have a look at the post links? I would be interested to have your opinion on whether the ruby part is possible.
        Cheers
        Chris
          Try something like this...
          def scenes2images()
            model=Sketchup.active_model
            view=model.active_view
            width=view.vpwidth.to_int
            height=view.vpheight.to_int
          ### you can change the width/height away from the default if you desire
            pages=model.pages
            pages_times=[]
            pages.each{|page|pages_times.push([page,page.transition_time])
              page.transition_time=0.0 }
          ### remembers pages' transition times and sets them all to 0
            filepath=File.dirname(model.path)+"\\" ### assumes model is saved
            0.upto(pages.count-1)do|images|
              ### this msgbox pauses and lets each view refresh and the image process...
              UI.messagebox("Exporting Image of Scene...")
              model.active_view.write_image("#{filepath+pages.selected_page.name}.jpg",width,height,true)
              Sketchup.send_action("pageNext;")
            end#loop
          ### reset pages' transition times
            pages_times.each{|array|array[0].transition_time=array[1]}
            UI.messagebox("Scenes' Image Exporting - Completed.")
          end#def
          save as scenes2images.rb and scenes2images in the ruby console to run it...
            chrisglasier
            Thanks again TIG. Here's your code that I have altered a bit (in black) to be later made into a callback. Hope that's OK with you.
            My regards
            Chris
            ` def scenes2images()
            %(#000000)[# variables from js in webdialog
            subdir = "E:/Chiang Mai/Scenes jpg/"
            w = 800]
            %(#000000)[width = w
            height = w/width*height]
            pages=model.pages
            pages_times=[]
            filepath=File.dirname(model.path)+"\" ### assumes model is saved
            ## changed to subdir variable - see above
            %(#000000)[# using 2 just for testing
            0.upto(2)do|images|]
            model.active_view.write_image("#{subdir+pages.selected_page.name}.jpg",width,height,true)
            Sketchup.send_action("pageNext:")
            %(#000000)[UI.messagebox("Exported "+pages.selected_page.name)]
            %(#000000)[## changed position to get correct scene name
            considering change to question with OK/Skip/Cancel + new position]
            end#loop
            UI.messagebox("Scene Image Exporting - Completed.")
            end#def`
              RickW
              SceneExporter and SceneExporterPro will do this as well.
              RickW
              www.smustard.com
                chrisglasier
                Very thoughtful and generous, thanks.
                You may be interested in seeing how this relates to my templates query
                Chris
