    From Revit 2010 to Sketchup
    19 Posts 7 Posters 3.9k Views 7 Watching
      Jorgensen
      I have just installed the 2010 version of Revit.
      Does anyone know if it's possible to export a Revit file to Sketchup ? I have tried to export to dwg, but SU don't recognise the fileformat 😞 it might be dwg 2010 format 😕
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        Doesn't the export allow you to choose the DWG version? (hope so, because we're about to install 2010 at our office.)
        If it doesn't, then do you have AutoCAD as well? Use that to re-save in 2007 format.
        • K Offline
          kwistenbiebel
          I tried it in and indeed it doesn't work .
          Revit 2010 should give you the option to export older DWG versions...but off course they don't as they want to force you to upgrade to the last version of Autocad as well.
          Damn Autodesk 😡
          They should have a Swastika as company logo.
          • K Offline
            kwistenbiebel
            What? Exporting as DWG from Revit 2009 and importing it in SU worked quite well .
            I hope it still works for Revit 2010 as our office just updated all our Revit licenses.
            Let me try....
              Well, that's interesting to know.
              Fortunately, we have a Revit + AutoCAD subscription. But it's very annoying to hear that this extra step is required.
                Jorgensen
                Hmm how irritating 😞
                I hope SU soon gets a update so importing dwg 2010 format becomes possible.
                We have autocad 2010 at the office, but plan to move to Revit, so importing dwg in Sketchup can become a source of irritation.
                • K Offline
                  kwistenbiebel
                  We have Autocad-Revit combos as well.....but going through Autocad is a fuss when you need a Revit model (or simply a 2D plan) in SU.
                    How about trying to use another CAD package to do some kind of conversion? Like Double CAD for instance (although AFAIK the free version can only handle 2D geometry).
                    • K Offline
                      kwistenbiebel
                      Did Double Cad adapt its software to Autocad 2010 already?
                      It is my guess that future Autocad and Revit releases will loose their backward compatibility (Revit already did).
                      That means that all other software that uses importers/exporters will need to put out service releases.
                      Will Google put out a new release of SU each year? I doubt it.
                        Well, at least SU is (can be saved) backward compatible. Also there are a whole bunch of CAD packages that can do the same - only the "industry standard" AutoCAD cannot.
                        I really wonder why that is the standard after all this. I wouldn't be surprised if "the world" got fed up with such a policy and wouldn't follow Autodesk policy so closely like a little puppy running after its mother. If they didn't, AD would certainly start losing market much faster.
                        • K Offline
                          kwistenbiebel
                          Most directors in architecture firms are a bit older and often not very CAD 'aware'.
                          They easily fall for Autodesk marketing serenades apparently.
                            That's why DoubleCAD Pro (full package) is now priced exactly like a "simple upgrade" for AutoCAD. The market (and dinosaur architecture managers and directors) should once realise that they are simply being ripped off. If they are not "techie" enough, they should be at least "cheap" enough - especially under these economic conditions.
                            • K Offline
                              kwistenbiebel
                              I think you're right Gaieus, but the current Autodesk success product is Revit, and not so much Autocad anymore.
                              Nowadays you get Autocad bundled with Revit.
                              Everybody is going Revit, but the funny thing is that you still need AutoCad as the plans you get from your consultants probably still are DWG files.
                                Yeah, you may definitely be right with Revit. I guess it's not "accidental" from AD that they form their policy around it (and also a reason for they haven't gone bankrupt yet)
                                • W Offline
                                  wmanning
                                  Regarding DoubleCAD or SketchUp having DWG 2010 compatibility, we both use the DWG from the Open Design Alliance. Our (IMSI/Design's) CTO is the chair of the ODA, and he assures me they are working feverishly to finish it. Once the ODA has the DWG 2010 libraries, it is up to us and Google to update our products to incorporate that version. So it could be some months still before the first version is implemented, and there is no telling in what timeframe Google plans to make their update.
                                  The good news is that Autodesk updates the DWG only every 3 years, so this isn't an annual event.
                                  And are you sure there isn't an option in Revit for DWG 2007 format??? That just seems bizarre to me.
                                  -- William
                                  • K Offline
                                    kwistenbiebel
                                    ...and indeed, an update: I just found out that the export window supports exporting to the older DWG versions (2007 and down). Sorry Autodesk, you guys don't seem to be as evil as we thought 😛 .
                                    • boofredlayB Offline
                                      boofredlay
                                      Whew. I was starting to panic.
                                      I thought you had to save down to 2004 for SU to open a dwg file, or am I wrong.
                                      ( I won't be near Revit until Tuesday )
                                        Good to hear!
                                        SU6 only supported 2004. SU7 supports 2007.
                                        • AnssiA Offline
                                          Anssi
                                          Autodesk also has the free TrueView application that besides having almost all the viewing and printing functionality of full AutoCad can convert newer DWG files to older (even very old) formats. There is a link (the "DWG From Autodesk" button)to the download on the main Autodesk webpage.
                                          Anssi
