    Drawing lines then creating a "face" (or importing)
    4 Posts 3 Posters 391 Views 3 Watching
      SFX Group
      Heres a very good question, if i draw 4 lines, all independant, then move each line to connect with the other (resulting in a 4 sided closed box) i can then group this, however how do i create a "face" between these lines so i can then "push/pull" the face to 3d?
      This goes for importing as well, i have saved a design (2D) from Corel Draw, saved as DXF, imported (it imported fine) then grouped all lines, but theres no "face" meaning i cant created the 3D object...
      Many Thanks
      Many Thanks
      Ashley
      Β© Copyright 2014 - http://www.ashleygriffin.co.uk
        remus
        If its quite a simple piece of linework, as in your first example, you can just drawover one of the lines and the face will appear.
        If it's more complicated, as with your second example, there is a handy little script called make faces that will find all the faces for you: http://www.smustard.com/script/MakeFaces
          SFX Group
          You da man 😍
          However i seem to have something already in 7 called "Create Face" under "tools>utilities", this worked when i selected all sides, then selected this, a face appeared and i can now make it 3d πŸ˜„
          Many Thanks
          Many Thanks
          Ashley
            @sfx group said:
            ...However i seem to have something already in 7 called "Create Face" under "tools>utilities", this worked when i selected all sides, then selected this, a face appeared and i can now make it 3d πŸ˜„
            Yes but it's generally more cumbersome (slower) than just drawing over a line.
