    Two problems with an 'Export to Vue' ruby script
    7 Posts 4 Posters 476 Views 4 Watching
      Alex Jenyon
      I've been working on a ruby script to take a SketchUP camera into 'Vue'. It's heavily based on Grant Marshall's 'camera2modo' ruby, and it's ALMOST working.
      However, I've come across a couple of issues I'm trying to solve, and my head is just about fried. The information may well be around, but if it is, it's not in a form I'm currently capable of understanding πŸ˜• - so your time / patience is appreciated!
      Problem #1:
       camscript.puts("cam.SetPosition(" + vx.to_s + ", " + vy.to_s + ", " + vz.to_s + ")")
      outputs something that looks like this:
       cam.SetPosition( 5.44m, -7.92m, 9.85m)
      I would like it to output this, WITHOUT the units:
       cam.SetPosition( 5.44, -7.92, 9.85)
      I thought that 'to_f' would be the correct command, but that doesn't seem to work... Any ideas on how I could do this?
      Problem #2:
      I need to calculate the 'roll' (i.e. z-axis rotation) of the camera.
      I've found a tutorial on highend3d on how to do this:
      http://www.highend3d.com/boards/index.php?showtopic=57543&mode=threaded&pid=57740
      And I'm pretty sure that in Ruby, (rather than MEL) it should look like this:
       # Calculate Y-rotation of camera (roll)
       globaly = [0, 1, 0]
       normal = zaxis.cross globaly
       projection = normal.cross zaxis
       cosine_roll = up.dot projection
       ry = Math.acos(cosine_roll).radians
        if (upy < 0)
        ry = -ry
      But this doesn't return the correct result. Does anyone know what I'm doing wrong?
      Many thanks for your time.
      AJ
      Concept artist / Matte painter
      www.aj-concepts.net
      • soloS Offline
        solo
        Alex I cannot help with the coding as I'm useless at such things but I would like to add my support and urge any of our code wizards to look into this as being a dedicated Vue user, such a facillity would be most welcome and very needed.
        I'm very happy someone (you) is doing an effort in making this feature possible.
        http://www.solos-art.com
        • Chris FullmerC Offline
          #1 try this:
          camscript.puts("cam.SetPosition(" + vx..to_f.to_s + ", " + vy.to_f.to_s + ", " + vz.to_f.to_s + ")")
          You were right thinking you wanted .to_f, but it still has to end up being a string. So keep the .to_s on the end also.
          I'll have to think about #2. Maybe someone else will come up with the answer faster,
          Chris
          All my Plugins I've written
            Alex Jenyon
            Thanks Chris...
            It's currently working perfectly for SketchUP scenes in which the camera isn't rotated in the z-axis (i.e. rolled / dutch tilted), and is above ground level.
            You also have to enter the camera 'field of view' by hand once you're in Vue.
            That's why I haven't posted it up yet - super user-unfriendly!
            If I can solve these two problems with Ruby, and the 'FoV' issue with Python, SketchUP and Vue are ready to go.
            AJ
            EDIT: I've just got problem#1 to work, using .to_f.to_m.to_s - your script still produced a value in inches. Thanks for the pointer, though...
            www.aj-concepts.net
              Oh good! I never get unit stuff right on the first try. Glad you figured it out.
              I'll keep thinking about the other issue.
              Chris
                SU always works in inches internally. Use .to_mm to turn the SU units to mm. Look at the Numeric class for other conversions: http://code.google.com/apis/sketchup/docs/ourdoc/numeric.html
                  Alex Jenyon
                  I've solved both problems now - please see my other thread for the finished plugin
                  www.aj-concepts.net
