    Two problems with an 'Export to Vue' ruby script
    7 Posts 4 Posters 399 Views 4 Watching
      Alex Jenyon
      I've been working on a ruby script to take a SketchUP camera into 'Vue'. It's heavily based on Grant Marshall's 'camera2modo' ruby, and it's ALMOST working.
      However, I've come across a couple of issues I'm trying to solve, and my head is just about fried. The information may well be around, but if it is, it's not in a form I'm currently capable of understanding πŸ˜• - so your time / patience is appreciated!
      Problem #1:
       camscript.puts("cam.SetPosition(" + vx.to_s + ", " + vy.to_s + ", " + vz.to_s + ")")
      outputs something that looks like this:
       cam.SetPosition( 5.44m, -7.92m, 9.85m)
      I would like it to output this, WITHOUT the units:
       cam.SetPosition( 5.44, -7.92, 9.85)
      I thought that 'to_f' would be the correct command, but that doesn't seem to work... Any ideas on how I could do this?
      Problem #2:
      I need to calculate the 'roll' (i.e. z-axis rotation) of the camera.
      I've found a tutorial on highend3d on how to do this:
      404 Not Found
      (www.highend3d.com)
      And I'm pretty sure that in Ruby, (rather than MEL) it should look like this:
       # Calculate Y-rotation of camera (roll)
       globaly = [0, 1, 0]
       normal = zaxis.cross globaly
       projection = normal.cross zaxis
       cosine_roll = up.dot projection
       ry = Math.acos(cosine_roll).radians
        if (upy < 0)
        ry = -ry
      But this doesn't return the correct result. Does anyone know what I'm doing wrong?
      Many thanks for your time.
      AJ
      Concept artist / Matte painter
      www.aj-concepts.net
      • soloS Offline
        Alex I cannot help with the coding as I'm useless at such things but I would like to add my support and urge any of our code wizards to look into this as being a dedicated Vue user, such a facillity would be most welcome and very needed.
        I'm very happy someone (you) is doing an effort in making this feature possible.
        • Chris FullmerC Offline
          #1 try this:
          camscript.puts("cam.SetPosition(" + vx..to_f.to_s + ", " + vy.to_f.to_s + ", " + vz.to_f.to_s + ")")
          You were right thinking you wanted .to_f, but it still has to end up being a string. So keep the .to_s on the end also.
          I'll have to think about #2. Maybe someone else will come up with the answer faster,
            Alex Jenyon
            Thanks Chris...
            It's currently working perfectly for SketchUP scenes in which the camera isn't rotated in the z-axis (i.e. rolled / dutch tilted), and is above ground level.
            You also have to enter the camera 'field of view' by hand once you're in Vue.
            That's why I haven't posted it up yet - super user-unfriendly!
            If I can solve these two problems with Ruby, and the 'FoV' issue with Python, SketchUP and Vue are ready to go.
            AJ
            EDIT: I've just got problem#1 to work, using .to_f.to_m.to_s - your script still produced a value in inches. Thanks for the pointer, though...
            www.aj-concepts.net
              Oh good! I never get unit stuff right on the first try. Glad you figured it out.
              I'll keep thinking about the other issue.
                SU always works in inches internally. Use .to_mm to turn the SU units to mm. Look at the Numeric class for other conversions: http://code.google.com/apis/sketchup/docs/ourdoc/numeric.html
                  Alex Jenyon
                  I've solved both problems now - please see my other thread for the finished plugin
                  www.aj-concepts.net
