    Texture on complex shape
    7 Posts 3 Posters 782 Views 3 Watching
    • A
      arcano
      Hi to all.
      I need to apply texture on my 3d skin that I've made for my work.
      The problem is one the curved surface. I've tried to projected texture with a parallel plane but when I project on curve the texture is stretched. I've tried to explain the problem with some images.
      I've attach the .skp file and the texture if someone of you want to try the solution.
      http://www.tyou.it/public/skin.rar
      Thank you very much and sorry for my poor english.
      • R
        remus
        If you go to hidden geometry (view->hidden geometry) you can see the faces your painting on to. this means you can then apply your projected texture by rotating it round then applying it.
        • A
          arcano
          Hi remus.
          I've tried it but what's happen in smooth corner ???
          • R
            remus
            The textures wont be perfect, but the method in the file should work reasonably well.
            corner UV thing.skp
            • A
              arcano
              Yes, It's work! Thankyou!
              • R
                remus
                Glad to hear it πŸ˜„
                • GaieusG
                  What you "marked" as an error is in fact not an error. Projected texture should behave like that (that's why it's called "projected" as if it were coming from a computer projector; it will be "distorted" on sides near parallel to the "projector rays").
                  Basically "wrapping" is what you need instead (Remus solution is something like that) although it is rather hard to do on such heavily triangulated surfaces you have (see especially images 3 and 4).
