    [Catalog] Matt666
    14 Posts 9 Posters 5.9k Views 9 Watching
      Matt666
      Hi all!
      I decided to create a topic containing all scripts I wrote. I don't know if it's a good idea, but I like it... Here we go!
      For many, these scripts have been published on this site. Some were created as a result of requests. Many have evolved as a result of testing and suggestions, thank you to all who participated.
      EDIT 20120202: Change topic title (thank you Dan Rathbun) EDIT 20120201: Normalize tool added
      • Cartouche
        Description: Create a cartouche (title block) with informations contained in the drawing title.
        Toolbar: Yes.
        Localization:
      • Menu Plugins/Cartouche/Add
      • Menu Plugins/Cartouche/Settings
      • Menu Plugins/Record existing cartouche
      • Help
        Command: 'Matt_Tools::Cartouche::go' & 'Matt_Tools::Cartouche::settings'. Commands appear in the ruby console when tool is activated.
      • Component/Groups tools
        Description:
      A set of tools to play with components and groups.* Make a group of just one entity (right click or menu plugins/Make group)
      • Make a component instance of just one entity (right click or menu plugins/Make component)
      • Convert each entity in the selection in a single group (right click or menu plugins/Convert on single groups)
      • Convert each entity in the selection in a single component (right click or menu plugins/Convert on single components)
      • Convert the selected component into a group (right click or menu plugins/Make group)
        Toolbar: No.
        Localization:
      • Menu Plugins/Convert in single components
      • Menu Plugins/Convert in single groups
      • Menu Plugins/Make component
      • Menu Plugins/Make group
      • Context menu/Convert in single components
      • Context menu/Convert in single groups
      • Context menu/Make component
      • Context menu/Make group
        Command: 'Several'
      • Components to groups
        Description: Converts all components to groups.
        Toolbar: No.
        Localization: Menu Plugins/Components to groups
        Command: c2g
      • Extend tool
        Description: extend edge you pointed on. It tries to work like acad Extend tool...
        Toolbar: No.
        Localization:
      • Menu plugins/Extend edges
      • Context menu/Selection/Extend edges
        Command: Matt_Edges.extend
      • Face 2 face
        Description: Redefine current view to the normal of the selected face.
        Toolbar: No.
        Localization: Context menu/Face2Face
        Command: Sketchup.active_model.select_tool Face2Face.new
      • Last entity drawn
        Description: Select last entity drawn.
        Toolbar: No.
        Localization: Menu Plugins/Select last entity drawn
        Command: entlast
      • Normalize
        Description: Puts entities to layer 0. Possibility to filter entity type to normalize by entering a web dialog.
        Toolbar: No.
        Localization:
      • Menu Plugins/Matt_Normalize/All
      • Menu Plugins/Matt_Normalize/Selection
      • Menu Plugins/Matt_Normalize/Filter options
        Command: 'Several'
      • Point
        Description: Draw a points by left-clicking or giving a distance.
        Toolbar: Yes.
        Localization: Plugins/Draw points
        Command: pointtool
      • Polar line
        Description: Draw a line with polar method.
        Toolbar: Yes.
        Localization: Menu Plugins/Polar line
        Command: polarline
      • Purge
        Description: Purge model. One step less than TIG script.
        Toolbar: yes.
        Localization: Menu Plugins/Purge
        Command: purger
      • Recall last tool
        Description: Recall last tool used.
        Toolbar: No.
        Localization: Menu Plugins/Recall last tool
        Command: Matt_Observer.recall_last
      • Reinit scale
        Description: Reinit scale of selected components.
        Toolbar: No.
        Localization: Context menu/Reset scale
        Command: scale_reinit
      • Remove group materials
        Description: Remove group materials but leave geometry material. Possbility to put group material on 'unmaterialed' geometry
        Toolbar: No.
        Localization: Menu Plugins/Remove C-G materials
        Command: Matt_Tools.remove_CG_mat
      • Selection_Manager
        Description: Manage (add, remove, etc) current selection.
        Toolbar: No.
        Localization:
      • Menu Plugins/Selection/Selection manager
      • Menu Plugins/Selection/Selected edges by angle
      • Menu Plugins/Selection/Selected edges by user-defined angle
      • Context menu/Selection/Selection manager
      • Context menu/Selection/Connected edges by angle
        Command: Matt_Tools.selection_manager
      • Shadow_now
        Description: Puts shadows on actual time.
        Toolbar: No.
        Localization: Menu Plugins/Shadows=Now!
        Command: Matt_Shadows.now
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13645&start=0&st=0&sk=t&sd=a:1rnnx9dw]Soften/Unsoften[/url:1rnnx9dw]
        Description: Soft / Unsoft edges in one action.
        Toolbar: Yes.
        Localization:
      • Menu Plugins/Soften edges/Soften
      • Menu Plugins/Soften edges/Soften all
      • Menu Plugins/Soften edges/Unsoften
      • Menu Plugins/Soften edges/Change normal angle
        Command: Several
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=20051:1rnnx9dw]Statistics[/url:1rnnx9dw]
        Description: Returns a report of all entities in the current selection
        Toolbar: No.
        Localization:
      • Menu plugins/Selection/Deep stats
      • Menu plugins/Selection/Simple stats
      • Context menu/Selection/Deep stats
        Command:
      • Matt_Selection.stats false (for a simple report)
      • Matt_Selection.stats true (for a deep report)
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11745&start=0&st=0&sk=t&sd=a:1rnnx9dw]Toggle units[/url:1rnnx9dw]
        Description: Change drawing units and precision quickly.
        Toolbar: Yes.
        Localization:
      • Menu Plugins/Toggle units/Decimal
      • Menu Plugins/Toggle units/Architectural
      • Menu Plugins/Toggle units/Fractionnal
      • Menu Plugins/Toggle units/Ingeniery
      • Menu Plugins/Toggle units/Feet
      • Menu Plugins/Toggle units/Inch
      • Menu Plugins/Toggle units/Millimeter
      • Menu Plugins/Toggle units/Centimeter
      • Menu Plugins/Toggle units/Meter
      • Menu Plugins/Toggle units/Decrease precision
      • Menu Plugins/Toggle units/Increase precision
      • Menu Plugins/Toggle units/Display format
        Command: 'Several'
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10739&start=0&st=0&sk=t&sd=a:1rnnx9dw]Zoom selection[/url:1rnnx9dw]
        Description: Zoom on selected. Works inside groups / Components.
        Toolbar: No.
        Localization: Context menu/Zoom on selected
        Command:zSel
      Frenglish at its best !
      My scripts
        My favorite : selection-manager β˜€
        • Chris FullmerC Offline
          Looks great Matt! Its nice to be able to see them all in one place with descriptions,
          Chris
          All my Plugins I've written
            I've noticed a bunch of the script-writers have links to all their plugins in their sigs - beneath each of their posts. So you can always check there too Bruce if you're looking!
            Chris
            • CadFatherC Offline
              CadFather
              that was a bit of time travel - great scripts and quickly written too.. Thanks Matt : )
              (just need to think of a new request now......)
              • EdsonE Offline
                Edson
                great idea, matt. i assume you will update it everytime you create a new plugin. and thanks for all the ones already available.
                http://www.mahfuz.arq.br
                  Matt666
                  Thank you all!
                  My scripts
                    dtrarch
                    Thank you, thank you, thank you
                    Really good work
                    dtr
                    • urgenU Offline
                      urgen
                      ...hi,Matt,good idea! πŸ‘ πŸ˜„ ...but "PURGE"page is absent... πŸ˜‰ ..."PURGE" only...
                      --------------------------------------------------I see also it ...
                      http://img36.imageshack.us/img36/9733/test39q.jpg
                      ..Discussion about it------> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13067&p=95518&hilit=+purge#p95518
                      --pupil forever...------
                        Matt666
                        Yes, I put this plugin on the french forum...
                        Perhaps I will create a new thread inside ruby forum...
                        Thank you urgen!
                        My scripts
                          Matt666
                          Plugins "Statistics" and "Extend tool" added to the first post.
                          My scripts
                            Matt666
                            Plugin "Nomalize" added in the first post.
                            My scripts
                            • Dan RathbunD Offline
                              Dan Rathbun
                              The topic title could be more specific.
                              [Catalog] Matt666
                              I'm all for organization. Very well done.
                              I'm not here much anymore.
                                Matt666
                                Ah! That's a good idea!
                                My scripts
