    Tris to Quads
    39 Posts 9 Posters 4.9k Views 9 Watching
    • R
      raduteo
      From what I understand Sketchup uses triangles, now, I want to use a model exported from SU into a program that uses quads (squares) but when importing the mesh looks screwed up, is there a way to convert tris into quads?
      Thank you.
      • R
        remus
        SU uses ngons as far as i'm aware. Id guess the problem is with the export format your using, as some of the require the mesh to be triangulated.
        Id suggest trying a few other export formats to see if you can find something that works.
        • GaieusG
          To my best knowledge, SU does not use triangulated faces (not even "hidden in the system from the user").
          Where do you want to export?
            Zbrush converts triangles in Quadrangles during the importation πŸ˜‰
            I don't know if "squarable" a circle is possible πŸ’š
            • K
              kwistenbiebel
              Are you sure? I had the impression everything in SU is triangulated mesh to describe surfaces.
              When doing exports, the triangulation becomes clear.
              • R
                raduteo
                Yes, the program I'm talking about is Zbrush, it can only import .obj
                I'm no tehnical expert so excuse me if I mangle technicall stuff, all I know is that exported models from SU are not usable in Zbrush, I googled first and others have this problem aswell so I guess I'd ask you guys since you do miracles.
                Example:
                http://img43.imageshack.us/img43/4777/412y.jpg
                Thanks!
                • GaieusG
                  No,I'm definitely not sure - I just said "to my best knowledge" (which of course doesn't necessarily mean too much).
                  I could imagine that "in the background", SU triangulates as well as many (almost most) surface modellers.
                  • R
                    raduteo
                    I'm sure I'm not the only numbskull using this program combo, it would be a huge relief for me if my SU models worked fine in Zbrush, would save me months/years of learning a new 3D program.
                    Thanks.
                    • Chris FullmerC
                      You'll probably have to do some serious diggin into how z-brush inports mesh and what it needs. It is a very special program in that it works fundamentally different than most other 3d modelers, so it will have special requirements probably. SU on the other hand is also special, so it creates geometry very differently than other 3d modelers. I would say SU achieves its speed in modeling through a lack of precision in its inner workings. Whereas z-brush achieves its results through extreme precision. Perhaps they are just too fundamentally different? Who knows, maybe my assessments are completely off base?
                      Chris
                      All my Plugins I've written
                      • FrederikF
                        Frederik
                        Like Gaieus, I also thought SU didn't triangulate the mesh...
                        If you export to obj-format you can tick and untick the "Triangulate all faces" in the options...
                        So - if things are already triangulated, why this option...?? πŸ˜•
                        Cheers
                        Kim Frederik
                        • R
                          raduteo
                          That did nothing as far as I can tell.
                            that can maybe help you πŸ˜‰
                            Merge button must be enable
                            Cursor weld activated
                            Tri to Quad also
                            For have this menu "Import"
                            create any volume 3D then Menu Tool / Make Polymesh 3D
                            You have now Menu tool/ Import πŸ˜‰
                            • R
                              raduteo
                              (missed some posts while posting the above message)
                              Yes, I know the 2 are very different programs but isn't there a program that I can use as a "middle-man"? SU can export in so many different formats there must be a program out there that can import the model, adjust it to suit Zbrush's needs, but the question is which is that program?
                              Thanks.
                              • K
                                Khai
                                it doesn't. I export from Sketchup in Quads...
                                • Chris FullmerC
                                  That's great to say, but how about an explanation of what you mean and how to do it.
                                  • K
                                    Khai
                                    simply model with quads and export. when I was trying out Pro, I just exported. now I'm using the free version and the export ruby, thats all I'm doing...
                                    the main thing I think is I don't leave any N-gons... I split them down into Quads before I export...habit from modeling in trueSpace for Poser..
                                    • R
                                      raduteo
                                      ..I would try what you said if it were more explicit (I mean, retard proof), I'm not really technical savvy, I'm just trying to model...
                                      Thanks.
                                        SU kmz -->Blender-->obj-->Zbrush
                                        SU skp-->DoublecadXt dxf 2000 2003-->Blender-->obj-->Zbrush
                                        πŸ˜‰
                                        • K
                                          Khai
                                          Thanks.
                                          it's simple. I make sure there's no faces with more than 4 sides (3 if I have no choice). that's all.
                                          if there is a face with more than 4 sides I draw in lines to split it down to 4.
                                          • K
                                            Khai
                                            πŸ˜‰
                                            well I'm using this http://sketchuptips.blogspot.com/2007/01/wavefront-obj-exporter.html without any issues...
                                            • 2 / 2
