    [Plugin] UV Toolkit
    377 Posts 86 Posters 375.9k Views 86 Watching
      hm... should be working fine on both system though...
      • DesertRavenD Offline
        DesertRaven
        @gaieus said:
        I am not the man of words,
        Would it make sense to create an arched texture and map it just flat on to your arch instead?
        simplicity is the ultimate sophistication
          jctiv4
          Hello,
          I am having an issue using his plug in
          I open sketch up and it reads:
          "Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_UV_Toolkit/loader.rb
          no such file to load -- TT_Lib2/core.rbError Loading File tt_uv_toolkit_2.rb
          no such file to load -- TT_Lib2/core.rb"
          I think I put everything in the right place but its not working. I am using windows 7 can you help?
            You have not installed the supporting 'Lib' as directed on the plugins main page...
            If you think you have installed it and there are still errors, then check your Plugins folder's security permissions are set to FULL and retry the installation...
            There are many other threads covering security permissions etc in very great detail...
              jumpjack
              I have a 3d model which has colours but no textures... at least, I can't see any texture upon exporting it in Collada (.dae) format.
              But I need a texture file to convert to VRML and to be able to upload file to Shapeways.
              Can I use this plugin to obtain a texture map from my colors?
              If not, how can I accomplish this task?
              • john2J Offline
                john2
                I'm getting the following error
                Error: C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_uv_toolkit_2.rb:48: invalid multibyte char (UTF-8)
                C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_uv_toolkit_2.rb:54: syntax error, unexpected tCONSTANT, expecting keyword_end
                loader = File.join( path, 'TT_UV_Toolkit', 'loader.rb' )
                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                  @John2
                  I posted a similar response to you in another thread. ๐Ÿ˜’
                  Do not copy plugins files/libs from an earlier SketchUp version.
                  Install the newest available ones - available from the PluginStore - they have been updated to suit v2014 ! ๐Ÿ˜ฎ
                  • speedjunkieS Offline
                    speedjunkie
                    Hi, I'm using UV toolkit with FredoScale for game modelling.
                    I've noticed that when I export the model(to dae), I get one texture for each quad face. I'm making a city model and this results in thousands of textures... Is this just how the plugin works or is it something I can do about it?
                    Edit: Never mind, Just found out that the faces has to be triangels...
                      speedjunkie
                      If I open a model made with skp 2013 and an earlier version of UV toolkit(and TT_lib) and try to edit the UV-mapping in Skp 2015 with the most recent UV-toolkit and TT lib , will the UV-mapping get messed up?
                        No - should act the same. Are you seeing otherwise?
                          maricanis
                          Hi Thom,
                          I was playing with UV Toolkit on a model from warehouse:
                          https://3dwarehouse.sketchup.com/model.html?id=1c056259336d676cf69f18f886bbb404
                          I tried to copy come textures from one face to another and get next error:
                          Could not compute valid matrix from points
                          C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_uv_toolkit2/clipboard.rb:230:in position_material' C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_uv_toolkit2/clipboard.rb:230:in block (2 levels) in paste_uv'
                          C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_uv_toolkit2/clipboard.rb:197:in each' C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_uv_toolkit2/clipboard.rb:197:in block in paste_uv'
                          C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/simpletask.rb:59:in block in run' C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/simpletask.rb:58:in each'
                          C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/simpletask.rb:58:in run' C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_uv_toolkit2/clipboard.rb:188:in paste_uv'
                          C:/Users/Marija/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/tt_uv_toolkit2/clipboard.rb:34:in block in <module:UV_Toolkit>' SketchUp:1:in call'
                          Surfaces I'm talking about are rectangles, below arches Problematic surfaces
                          I've inspected them a bit, it is definitely rectangle, and seems problem is that for UVQ coordinates we get 2 pairs of identical coordinates.
                          ` face=Sketchup.active_model.selection[0]
                          face.vertices.each{|v| puts v.position}
                          (-81.244783m, 48.236298m, 29.144603m)
                          (-81.244783m, 48.236298m, 25.126711m)
                          (-78.64126m, 46.296916m, 25.126711m)
                          (-78.64126m, 46.296916m, 29.144603m)
                          tw=Sketchup.create_texture_writer
                          uvh = face.get_UVHelper( true, false, tw )
                          uvq = face.vertices.collect { |v|
                          uvh.get_front_UVQ( v.position )}
                          [Point3d(-0.77926, 0.615652, 1.07232), Point3d(-0.77926, 0.615652, 1.07232), Point3d(-0.770337, 0.611328, 1.07188), Point3d(-0.770337, 0.611328, 1.07188)]`
                          Is there some solution for surfaces with such coordinates?
                          I've tried slight change in plugin code: removing of duplicates (and their corresponding vertices coordinates) and then position_material -> no error, but final texture not positioned as original one.
                          Thanks in advance,
                          Marija
                            Hm... I think this relate to projected textures. The API doesn't have good support for that type of mapping. ๐Ÿ˜•
                              maricanis
                              You are right. I've checked and these are projected textures.
                              I know not much useful things in API on mapping of projected textures.
                              Do you think there is some possibility to 'extract' that info and use it for pasting. Something with get_texture_projection() and set_texture_projection().
                              Marija
                                get_texture_projection and set_texture_projection was an attempt to add support for that. It was added close to a release a while back. Though it didn't really fully solve things. (and should probably be deprecated.) As things are right now there aren't any good info to go by.
                                • OxerO Offline
                                  Oxer
                                  I noted when you save UVs data and then you save the .skp file the size of the file increases notably, is there any way to cleanup that data after it has been used?
                                  It would be fantastic to add a feature to clean the data.
                                  Example: UVs data of 6000 faces, the file increases about 4mg, if you have saved the UVs of various objects the increment can be immense.
                                  http://www.oxervision.blogspot.com/
                                  • OxerO Offline
                                    Oxer
                                    Excuse me but I'm waiting an answer, please I need a solution, I use the plugin many times in my personal projects.
                                      roro1433
                                      thank you
                                      • 15
                                      • 16
                                      • 17
                                      • 18
                                      • 19
                                      • 19 / 19
