    [Plugin] UV Toolkit
    377 Posts 86 Posters 324.8k Views 86 Watching
      Can you post a sample model please?
      • V Offline
        vanman
        I've PM'd you.
        Thanks for the help.
          @vanman said:
          I used the plugin to use the "Frontface Material to Backface", and it worked fine, but when I check for errors in SU, it says: "The front or back texture coordinates for CFaceTextureCoords (48) is not valid" for every face and when I click fix, it reverts to the way it was before using the plugin (no textures on the backfaces).
          Any ideas? Or is this normal?
          Thanks.
          Huh! That's odd. Don't know what's going on here. πŸ˜• Never seen that before - and the model looks to be fine. I'll have to investigate.
            Is there a very tiny facet that returns invalid coordinates, that are regarded as the same because of the 'rounding' of its very close vertex-points ?
            I just had a perhaps somewhat similar issue with my Octane Exporter [on their forum]... Someone has made a very small object that would have had overly tiny facets when created, if they hadn't scaled it up to process and then back down when done - the small facets can exists, it's just making them that's the issue. So far so good... now they exported it to OBJ format for use in Octane and there were tiny holes in the object when it rendered. Octane requires the OBJ to be in 'm' and have triangulated faces. In processing the meshes my tool uses the API methods to triangulate the mesh's faces. I now think that what was happening was that the triangulation of some tiny quad faces resulted in two triangulated facets that are so small that they have two vertices that 'round' to be at the 'same point' [the OBJ format is set to 'm' 6 d.p.] - therefore that new facet can't exist as its only a 'line' at best, and the two parts can then be missed, out leaving a small quad shaped hole when the object is reformed from the OBJ data...
            This could of course also mess with the tiny face's texture mapping ?
              It's a 1:1 scale building with textures...
                BUT might it still not have a very tiny textured facet somewhere that is thereby tripping things up ?
                  I'm not finding any small faces...
                  Sketchup.active_model.selection.each { |f| puts f.area }
                  90921.1990251775
                  8884.83094815197
                  89096.7297450352
                  8797.85733797857
                  73856.383925685
                  141994.698396594
                  9102.23521971269
                  12145.8874379084
                  24291.7748758168
                  72875.3920821179
                  44959.9790473181
                  14734.602162027
                  17691.3311847609
                  24392.7484579021
                  30011.1066867323
                  5913.42252781615
                  106356.388178604
                  34341.9813095441
                  3545905.862747
                  4551.09075463125
                  141994.698396594
                  50062.2342056662
                  104443.19428945
                  427926.997414128
                  498.944000443444
                  1387.04002680257
                  555.234138673402
                  1387.04002680257
                  498.938868995756
                  1387.04002680257
                  555.228428303232
                  1387.04002680257
                  498.945026732981
                  1387.04002680257
                  555.235280747436
                  1387.04002680257
                  498.945026732981
                  1387.04002680257
                  555.235280747436
                  1387.04002680257
                  13652.9721252099
                  153511.061835866
                  543.299207966775
                  1387.04002680257
                  604.593436356126
                  1387.03753654542
                  27697.347044386
                  4359.49237901717
                  4451.34639743716
                  4451.35947758332
                  4451.35424552485
                  4451.35424552485
                  4451.36013159063
                  4451.3599680888
                  36670.6765526049
                  4451.35362924216
                  4451.35379274376
                  4451.34790668637
                  4451.34790668637
                  4451.35313873738
                  4451.34005860984
                  4359.49925111979
                  30024.5993279971
                  67236.1596991253
                  17251.2833128222
                  21472.4971347198
                  25566.7510791362
                  128807.275064796
                  493528.467044927
                  23028.3607461373
                  18401.0262709489
                  130944.016437284
                  511510.510285885
                  22920.9833744596
                  20675.3865149603
                  125516.784053139
                  9609.28530909866
                  7391.72898352146
                  7391.72898352146
                  182.619508624077
                  213.451079707593
                  5652.52077005804
                  5652.52077005804
                  613232.018621877
                  18262.0502714831
                  9102.22363510579
                  362053.963948095
                  13639.6107236221
                  23326.5092276735
                  263054.266003366
                  661.054059026763
                  44600.8861230744
                  75814.7493808884
                  12669.2358815777
                  35555.4855367881
                  12669.2358815777
                  8522.23635725677
                  8522.23635725677
                  668996.234413132
                  543.287712531164
                  1387.03753654542
                  604.58207642406
                  498.938121928659
                  1387.03753654542
                  555.228912425377
                  1387.03753654542
                  498.93825021456
                  1387.03753654542
                  555.229055184646
                  1387.03753654542
                  498.937737070955
                  1387.03753654542
                  555.228484147571
                  498.942868507002
                  1387.03753654542
                  555.234194518316
                  1387.03753654542
                  498.937737070955
                  1387.03753654542
                  555.228484147571
                  1387.03753654542
                  498.943894794211
                  1387.03753654542
                  555.235336592465
                  1387.03753654542
                  498.943894794211
                  1387.03753654542
                  555.235336592465
                  1387.03753654542
                  261012.344038505
                  13652.9721252099
                  1387.03753654542
                  498.939253854332
                  1387.04002680257
                  555.228856580994
                  1387.04002680257
                  498.939382140525
                  1387.04002680257
                  555.228999340249
                  1387.04002680257
                  498.938868995756
                  1387.04002680257
                  555.228428303232
                  1387.04002680257
                  6522.12890144438
                  11305.0324846641
                  16957.5094865821
                  11305.0324846641
                  16957.5094865821
                  18109.752711948
                  201171.422032186
                  165547.943793187
                  Btw vanman - your SketchUp file is 8 MB because the texture you used is 8MB JPG - 4096x4096 pixels. The very max SketchUp will display is 2048x2048 if you enable large textures.
                    I'm out of ideas then πŸ˜•
                    • V Offline
                      vanman
                      Ok,
                      Thanks for looking into it. I'll just deal with it on a model by model basis.
                      I'll reduce the image size, I didn't know about the SU max texture size.
                      πŸ˜„
                        I've not had time to dig deep into this. I've a wee bit busy for the time being. Trying to get some stuff ready for Basecamp.
                        • usenU Offline
                          usen
                          Thanks. πŸ‘
                          http://www.sketchupturkiye.com/
                            mannomann
                            sorry for that question: I put the plugin into the plugin folder. But no plugin is in SU. What is wrong?
                            J.
                            Cannot read 23 pages for installing problems. Tried to use the search, but no results for that problem.
                              @mannomann said:
                              ...Cannot read 23 pages for installing problems...
                              Just read the first post and make sure you follow the instructions carefully. Have you also installed the TT_Lib library for instance?
                                mannomann
                                DidnΒ΄t and donΒ΄t find installing instructions. And in the downloaded file I also do not see the TT_lib library.
                                  mannomann
                                  Ok - thank you.
                                  The missing TT_Lib was the problem.
                                  Best regards
                                    The Firle Fanz
                                    I already installed the TT_UV_Toolkit at my Laptop at home.
                                    Here on my businesss PC I donΒ΄t know anymore and canΒ΄t remember where to put the TT_Lib???!!!
                                    And I still do not find a installing instructions for that.
                                    Would somebody please be so kind and show me the install passage?
                                    Or any hint?
                                    Thanks in advance MM
                                    OK - found it.
                                    MM
                                      dickorama
                                      You sure these UV things work on Sketchup 8? I've been getting a lot of errors, namely:
                                      Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_UV_Toolkit/loader.rb
                                      no such file to load -- TT_Lib2/core.rbError Loading File tt_uv_toolkit_2.rb
                                      And before you ask, creating the TT_Lib2 folder and placing core.rb in it did not work well. And it's not really my job to try and "hack" plugins so they work.
                                        It's also not my job to create plugins. I create tools to do my job and I release them for the public to use as is. The least you can do is take a moment to read the instructions of the free tool you're trying to use.
                                        If you go back you will see at the bottom of the thread the footprint of where the files should be. You should not manually create a TT_Lib2 folder and move the core.rb file from UV Toolkit into it. You should install the required TT_Lib2 support library as link right above the UV Toolkit download button, labeled Requirements. It's all there, at a glance. In no way are you supposed to "hack" anything! πŸ˜’
                                        If you have trouble installing plugins you can use this utility: http://sketchucation.com/forums/viewtopic.php?f=323&t=42315&p=375454#p375454
                                        It let you install RBZ and ZIP packages. It's an RBZ package itself so follow the instructions in the thread (lots of screenshots) on how to use the Install Extension feature in SketchUp.
                                        For a complete breakdown on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                        (However, installing them to the correct location wasn't the issue here, it was because you didn't read the instructions!)
                                          rv1974
                                          I've got constant 'Don't panic!' pop-up that 'fixes' the error after applying 'front face mat to back face' (as a result backfaces are messed). Could you take a look at the attachment?
                                          green_example.skp
                                            I got a warning when I first opened the model. When I said fix problems that reset the backside textures. But when I ran the plugin again, front side to backside and used the Fix Problems button - I got no errors.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
