    Removing observers
    4 Posts 2 Posters 365 Views 2 Watching
      How do you remove observers? What is the argument to pass on?
      I've been using an entities observer to monitor the enitites of the active path. Whenever the path changes I need to remove the observers watchign the old path. But now?
      http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#remove_observer
      The example in the manual doesn't give much of a clue. Just says observers. I tried passing my Observer class, but that didn't do anything. The remove_observer method return false every time.
        @tig said:
        http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#remove_observer ?
        That would be the same link I provided in my OP. It's not obvious to me what it does and what the observer is.
        I've tried to make store the return value when I do MyEntitiesObserver.new ( myTemp = MyEntitiesObserver.new )
        And then I try entities.remove_observer( myTemp ) and that returns true. But the old observers still triggers... 😞
          You need to pass the observer to the 'remove_'... You must have an entity_ or entities_observer ?
            Ok. Found the problem. I was using model.active_path to cache the last path. When the last path was the model itself it'd return an empty array.
