    Bush Lodge - Vray - updated
    60 Posts 39 Posters 14.7k Views 39 Watching
    • free agentF Offline
      free agent
      those are the same renders, same front and rear, same angles, same building
      i think i understand ur problem, the Lodge has 2 roofs in an L shape, the views dont show both, the client specified view angles
        troyhome
        This is absolutely amazing stuff! I love that it's not all done in SU, but that Photoshop was used. This is a great time saver as far as rendering times go. But i always wonder how much time goes into the post-renders in ps- that must be very time consuming. I'd be interested in how long that takes you.
        IOviz.com
        SU Pro 2024 PC
          free agent
          the model took 3 days cos i was faffing with textures, and the Photoshopping for both took another day, maybe less coss i finished the first one the same evening i finished rendering, then finished the second render the following morning, it really is quick.
          • holmes1977H Offline
            holmes1977
            Insane, Pure Perfection......Such a fan
            Exaggeration makes a dull story better.
            • olisheaO Offline
              olishea
              amazed. If I wasn't told that it was a render I'd probably think it was a photo. transition between photo and render is seamless.....really well done, inspiring stuff, hopefully my renders will be like that one day!!
              oli
                rcossoli
                I like your work because it is a super combination of a 3D model rendering (and rendering it necessary) and work in photoshop, it's more than just a render, is a work of composition, congratulations!!!
                sorry my inglishhhhh
                THREEDIMENSIONSWEB dot COM
                  troyhome
                  I aspire to be this good.
                  IOviz.com
                  SU Pro 2024 PC
                  • marked001M Offline
                    marked001
                    i really hope you have a chance to share your methods....would be great. like rcossoli said, this is that digital art is all about... mixing methods and media to create a beautiful cohesive image. its even greater when you see the state of the raw render.
                    great stuff... def some of the best we've seen on here..
                    http://www.revision21vis.com
                    instagram: revi21on
                      free agent
                      wow thanks, i also see it as a painting/rendering mix type thing, Mike Lucey has contacted me about a tutorial which i hope to have time for, so i do intend on sharing my methods. thanks again for the kind words
                        πŸ‘ πŸŽ‰ πŸ‘
                        • 9 Offline
                          9fly
                          Can not believe. Is it the grass are render?
                          • cucsat2003C Offline
                            cucsat2003
                            The perfect combination of renderings and images in photoshop.You're master,Free Agent!
                            • olisheaO Offline
                              olishea
                              Free Agent: Please could you post the gabion wall texture you used in this scene? it looks amazing...i'd be really grateful. πŸ˜„
                              oli
                                rev3rse
                                An incredible work..
                                when you combine 3D + real photos + PP = matte painting, a new shape of art.. πŸ‘
                                  madhav
                                  beautiful results. πŸ‘
                                  • romboutR Offline
                                    rombout
                                    wanted to share my latest render, hot out the oven πŸ˜„
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/bushlodge-02-1.jpg
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/bushlodge-01.jpg
                                    wow wow wow
                                    great image, done with vray 4 su!!!
                                    love it, im learning thea at the moment.
                                    I need to model a palapa soon and i came across this image of yours. Where did you find the text of that thatced roof.
                                    And how did you do the grass at the fore ground, looks insane real! to me
                                    and huh where do you get your skies from, it look great
                                    where's your psd file with layers, you said you was planning to post it???
                                    πŸŽ‰
                                      skyscraper100
                                      great renders! youre a master πŸ‘
                                      The way you think Creates reality for yourself.
                                        troyhome
                                        more more more, please!
                                        IOviz.com
                                        SU Pro 2024 PC
                                          leminilab
                                          πŸŽ‰
                                          πŸŽ‰
                                          πŸŽ‰ πŸŽ‰
                                          Wow... I'm seasick...
                                          ... Last time I'm using this bouncin' emoticon... 🀒
                                          • "Live every day as if it were your last and then some day you'll be right."
                                          • "ThomThom rules!!!"
                                          • Z Offline
                                            zbusheha
                                            Ohh … " Mastering " πŸ‘
                                            • 3 / 3
