    'require' problem with RBS
    13 Posts 6 Posters 1.1k Views 6 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      I have a main script in the Plugins folder and it requires other scrambled files in a sub-folder (it's a commercial plugin)
      require 'myFolder/myscript'
      doesn't work if myscript is a RBS, I get a "No such file to load" eror message.
      require 'myFolder/myscript.rbs'
      doesn't work either.
      Anyone knows how to do ?
      Thanks in advance,
      Edit:
      Sketchup::require instead of require , as said here http://code.google.com/intl/fr/apis/sketchup/docs/tutorial_distributing.html ???
      DB
        Try
        require '/myFolder/myscript.rbs'
        Also the Sketchup::require...
        for scrambled scripts should work ?
          Didier Bur
          Sketchup;;require 'myFolder/myScript'
          Works 👍
          Another problem: when there is a path in the code of a scrambled script, it is not found anymore on execution, for instance:
          def createNewCmd(menuItemName, smallIcon, toolTip, &action)
             iconsFolder= "myPluginFolder/Icons/"
             cmd = UI;;Command.new(menuItemName) { action.call() }
             cmd.small_icon = iconsFolder + smallIcon + "_Small.png"
             cmd.large_icon = iconsFolder + smallIcon + "_Large.png"
             cmd.tooltip = toolTip
             return cmd
          The PNG image is not found when the toolbar displays, resulting in a blank icon 👎
          Any hint someone ?
          DB
          • tbdT Offline
            tbd
            Sketchup::require is needed for .rbs files as stated in documentation
            you need a direct path for the icons, use find_support_file(s). also use File.join to add the icons names (I had some troubles using concatenation on Mac)
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
            • JuantxoJ Offline
              Juantxo
              Also long lines does not work in .rbs but does in .rb (like a large comment in same line).
                Example?
                • Dan RathbunD Offline
                  Dan Rathbun
                  Possible problems:
                  1) You String delimeter is "
                  You may want to use %[] (same as %Q[],) which is a double-quoted string ...
                  ... or %q[] which is a single-quoted String.
                  You can use any delimeters you wish when using the % syntax... such as [ ... ], { ... }, ( ... ), and then you do not need to escape nested " (double quote characters.)
                  2) You are embedding **\r \n \t** characters in an HTML string .... I think the browser will have problems with this, as Ruby will evaluate the double-quoted string and replace them.
                  I think you need to replace these with HTML friendly & codes:
                  see: [ISO Latin-1 Character Set](http://msdn.microsoft.com/en-us/library/aa752007(v)
                  and: [Additional Named Entities for HTML](http://msdn.microsoft.com/en-us/library/aa752008(v)
                  and: [Character Entities for Special Symbols](http://msdn.microsoft.com/en-us/library/ms537499(v)
                  Assign your HTML string to a reference:
                  **html = %q[** ... *the string here* ... **]**
                  then:
                  html.gsub!('\n','
                  html.gsub!('\r','
                  [ruby:1xwj7b05]html.gsub!('\t',' ')[/ruby:1xwj7b05]
                  3) There may be a length limit to the string passed to [ruby:1xwj7b05]eval()[/ruby:1xwj7b05]
                  I'm not here much anymore.
                  • JuantxoJ Offline
                    Juantxo
                    Example of huge lines in .rb file not working in .rbs. All comment is in the same line.
                    puts('Hola caracola')
                    #"<TABLE width=\"100%\" border=0>\r\n<TBODY>\r\n<TR>\r\n<TD align=left>\r\n<P class=title>Performance of Grid-connected PV <BR></P>\r\n<P><FONT color=#00ed00>NOTE; before using these calculations for anything serious, you should read </FONT><A href=\"javascript&#058;window.open('PVcalchelp_' + 'en' + '.html','help','height=600,width=600,toolbar=no,scrollbars=yes,resizable'); void 0;\"><FONT color=blue>[this]</FONT></A> </P>\r\n<P class=subtitle align=left>PVGIS estimates of solar electricity generation </P>Location; 46°11'54\" North, 6°8'32\" East, Elevation; 382 m a.s.l.,<BR><BR></TD></TR>\r\n<TR>\r\n<TD align=left><BR>Solar radiation database used; PVGIS-classic <BR><BR>Nominal power of the PV system; 14.5 kW (crystalline silicon)<BR>Estimated losses due to temperature; 7.8% (using local ambient temperature)<BR>Estimated loss due to angular reflectance effects; 3.4%<BR>Other losses (cables, inverter etc.); 14.0%<BR>Combined PV system losses; 23.4% </TD></TR>\r\n<TR>\r\n<TD align=left><BR></TD></TR>\r\n<TR>\r\n<TD align=left>\r\n<TABLE class=data_table width=300 border=1>\r\n<TBODY>\r\n<TR>\r\n<TD colSpan=5><B>Fixed system; inclination=12°, orientation=12° </B></TD></TR>\r\n<TR>\r\n<TH align=left>Month</TH>\r\n<TH width=40><SPAN class=formula>E</SPAN><SUB>d</SUB> </TH>\r\n<TH width=40><SPAN class=formula>E</SPAN><SUB>m</SUB> </TH>\r\n<TH width=40><SPAN class=formula>H</SPAN><SUB>d</SUB></TH>\r\n<TH width=40><SPAN class=formula>H</SPAN><SUB>m</SUB> </TH></TR>\r\n<TR>\r\n<TD>Jan </TD>\r\n<TD align=right>15.60</TD>\r\n<TD align=right>484</TD>\r\n<TD align=right>1.31</TD>\r\n<TD align=right>40.7</TD></TR>\r\n<TR>\r\n<TD>Feb </TD>\r\n<TD align=right>24.40</TD>\r\n<TD align=right>683</TD>\r\n<TD align=right>2.05</TD>\r\n<TD align=right>57.5</TD></TR>\r\n<TR>\r\n<TD>Mar </TD>\r\n<TD align=right>40.60</TD>\r\n<TD align=right>1260</TD>\r\n<TD align=right>3.51</TD>\r\n<TD align=right>109</TD></TR>\r\n<TR>\r\n<TD>Apr </TD>\r\n<TD align=right>50.90</TD>\r\n<TD align=right>1530</TD>\r\n<TD align=right>4.51</TD>\r\n<TD align=right>135</TD></TR>\r\n<TR>\r\n<TD>May </TD>\r\n<TD align=right>55.30</TD>\r\n<TD align=right>1710</TD>\r\n<TD align=right>5.05</TD>\r\n<TD align=right>157</TD></TR>\r\n<TR>\r\n<TD>Jun </TD>\r\n<TD align=right>61.80</TD>\r\n<TD align=right>1850</TD>\r\n<TD align=right>5.76</TD>\r\n<TD align=right>173</TD></TR>\r\n<TR>\r\n<TD>Jul </TD>\r\n<TD align=right>65.80</TD>\r\n<TD align=right>2040</TD>\r\n<TD align=right>6.16</TD>\r\n<TD align=right>191</TD></TR>\r\n<TR>\r\n<TD>Aug </TD>\r\n<TD align=right>58.90</TD>\r\n<TD align=right>1830</TD>\r\n<TD align=right>5.49</TD>\r\n<TD align=right>170</TD></TR>\r\n<TR>\r\n<TD>Sep </TD>\r\n<TD align=right>46.80</TD>\r\n<TD align=right>1400</TD>\r\n<TD align=right>4.22</TD>\r\n<TD align=right>127</TD></TR>\r\n<TR>\r\n<TD>Oct </TD>\r\n<TD align=right>30.00</TD>\r\n<TD align=right>931</TD>\r\n<TD align=right>2.64</TD>\r\n<TD align=right>81.9</TD></TR>\r\n<TR>\r\n<TD>Nov </TD>\r\n<TD align=right>18.20</TD>\r\n<TD align=right>546</TD>\r\n<TD align=right>1.56</TD>\r\n<TD align=right>46.8</TD></TR>\r\n<TR>\r\n<TD>Dec </TD>\r\n<TD align=right>13.20</TD>\r\n<TD align=right>410</TD>\r\n<TD align=right>1.12</TD>\r\n<TD align=right>34.7</TD></TR>\r\n<TR>\r\n<TD colSpan=5></TD></TR>\r\n<TR>\r\n<TD><B>Yearly average </B></TD>\r\n<TD align=right><B>40.2 </B></TD>\r\n<TD align=right><B>1220 </B></TD></TD>\r\n<TD align=right><B>3.62 </B></TD>\r\n<TD align=right><B>110 </B></TD></TR>\r\n<TR>\r\n<TD><B>Total for year</B></TD>\r\n<TD align=right colSpan=2><B>14700 </B></TD>\r\n<TD align=right colSpan=2><B>1320 </B></TD></TR></TBODY></TABLE></TD></TR>\r\n<TR>\r\n<TD><BR></TD></TR>\r\n<TR>\r\n<TD>\r\n<P><SPAN class=formula>E</SPAN><SUB>d</SUB>; Average daily electricity production from the given system (kWh)<BR><SPAN class=formula>E</SPAN><SUB>m</SUB>; Average monthly electricity production from the given system (kWh)<BR><SPAN class=formula>H</SPAN><SUB>d</SUB>; Average daily sum of global irradiation per square meter received by the modules of the given system (kWh/m<SUP>2</SUP>)<BR><SPAN class=formula>H</SPAN><SUB>m</SUB>; Average sum of global irradiation per square meter received by the modules of the given system (kWh/m<SUP>2</SUP>)<BR></P></TD></TD>\r\n<TR>\r\n<TD>\r\n<TR>\r\n<TD><BR>\r\n<P>PVGIS © European Communities, 2001-2010<BR>Reproduction is authorised, provided the source is acknowledged<BR>See the disclaimer <A href=\"http://europa.eu/geninfo/legal_notices_en.htm\" target=legal>here </A></P></TD></TR></TBODY></TABLE>\r\n<SCRIPT language=JavaScript>\r\n\t\topener.window.setAngles(12,12,1,1);\r\n\t</SCRIPT>\r\nwindow.focus(); </SCRIPT>"
                    • JuantxoJ Offline
                      Juantxo
                      Sorry, this example is more clear. Length is the problem.
                      #aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
                        Dan Rathbun
                        So... what happens if you wrap the very long string inside
                        ` =begin
                        =end`
                        like:
                        =begin
                        =end
                          Dan Rathbun
                          Another thing you can do to make your life easier.. is to use a HERE DOCUMENT block:
                          See: The Ruby Language > The Basic Types > Strings
                          mywebpage = <<HTML
                            This is a DOUBLE quoted string document.
                            Sum = #{a + 1}
                          HTML
                          mywebpage = <<-"HTML"
                              The above used #{a + 1}
                            HTML
                          mywebpage = <<-'HTML'
                              This is a SINGLE quoted string document.
                           HTML
                          Myself I use:
                          mystring = %q{
                            .. a bunch of,
                            ... lines of text
                            Dan Rathbun
                            By the way.. in the first example... http://forums.sketchucation.com/viewtopic.php?f=180&t=18903&p=386932#p386841
                            The first and last **"** are not escaped ...
                            .. if Google's code that passes it to eval() uses literal **"** characters .. that might cause problems. (guessing here.)
                            I tried passing your long comments to eval() in the console, but got no error.
                            • JuantxoJ Offline
                              Juantxo
                              =begin
                              =end
                              The same, .rbs fails.
                              Thank you Dan for your advice.
                              Really I don't look for a solution.
                              I only want to advert others about this. It's difficult to debug this error.
                              Yesterday I scrambled the code but it didn't work. It was difficult to find out why. After a long time I discovered that by mistake I put a comment too long in same line and that was the reason.
