    Modeling from plans
    27 Posts 23 Posters 3.5k Views 23 Watching
    • soloS Offline
      solo
      Architectural modeling from plans and elevations can be a tedious task and even frustrating.
      I'd like to know if anyone actually enjoys it and excels in it who would be willing to possibly in future be a resource one can outsource such work to.
      This is not necessarily a job request but more of a resource locator for future projects (I have sneaking suspicion the market is about to correct itself very soon)
      You can reply here of PM me if you want.
      (kicking tires)
      http://www.solos-art.com
        bubbalove
        This is how I do all my architectural models Pete. If you ever need me just give me a shout...
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
          tomsdesk
          Pete,
          I do enjoy it! After years spent coaxing architectural drawings from a blank screen, this next level in our relationship is always a hoot. Give me a call anytime.
          Best, Tom.
          2.5D Trees & Shrubs!
          • StinkieS Offline
            Stinkie
            I'll gladly do anything that isn't more complicated than the Barcelona Pavillon. 💚 Beyond that ... probably a very bad idea. 😉
            • P Offline
              Pg09
              (kicking tires)
              God i hope you are right!
              Guys i was wondering how you proceed when you have all the elevation in SU.
              I guess you create the flat floor plan and then extrude the walls using the elevation as a reference?
              Thats all are there other tricks?
              • arail1A Offline
                arail1
                Could you elaborate a bit on what part of the process you find to be frustrating?
                I have to input architect's drawings into SketchUp to position my stairs in (or I did before the Collapse - hope you're right about the Recovery) and I find it tedious, but not difficult. Maybe that's what you're saying - tracing over all those lines and then pulling them upwards is tedious?
                I watched a video showing someone doing this in Modo (I'm doing a trial of Modo right now) and it was kind of interesting. They were clicking on every corner (vertex) and thus creating polygons of the wall shapes in plan and then pulling it up into elevation. I'm not sure if this would be much faster than drawing over the lines in SketchUp but maybe it would be. Let me know if you think this would be worth looking at and I'll dig up the link.
                  bubbalove
                  Why do you need to trace? All you have to do after you bring it in is use the 'MakeFaces' ruby. It doesn't work all the time but it does fill in most faces so you don't have to trace that much to get the faces...
                  It also depends on who did the drafting. I sometimes find that some people don't close there corners or intersections which can be very annoying but you have to make sure everything is good in AutoCAD before importing into Sketchup. IMO, that can be the most tedious part...
                  • arail1A Offline
                    arail1
                    Understood. As you say, it's the quality of the previous drawing that determines. Architects in NYC often have a kind of disdain for competent AutoCAD drafting conventions - I think it's because they're trained to think of themselves as artists, not technicians. As a result there's an awful lot of correction that I have to do - even using MakeFaces. Clearly it's the same or similar wherever you are.
                    But you're right, MakeFaces is a necessary ruby for this work and it's good that you mention it for anyone who's following this thread..
                    • G Offline
                      galbavy1
                      YOU GOTTA USE THE "LABEL STRAY LINES" AFTER YOU USE MAKE FACES.... IT SAVES LIVES! I also find it very useful to select all geometry and intersect selected, that picks up alot, even though SU7 is supposed to do that automatically, I find it doesn't.
                      • G Offline
                        galbavy1
                        I wish that after you extrude the floor plan that there was a way to "project" the linework elevation onto the sides of the building. Mabee drape could work???? I tried this method shown above a couple weeks ago...still kinda a pain, I ended up placing components on the elevations - scaling the windows ie to fit, then placing them on axis by moving the individually.
                        • boofredlayB Offline
                          boofredlay
                          I too enjoy this type of work.
                          Add me to your list if you like.
                          • brodieB Offline
                            brodie
                            "label stray lines"?
                              lucifer1101
                              Yes i also do this from floor plans, but not for long...
                              can i ask where all of you get the floor plans and elevations, preferably CAD but pictures are ok....
                              if you want to see a house im doing right now just have a peek here ok...
                              Page not found | Dark Design Studio
                              Where i will make it happen
                              (darkdstudio.wordpress.com)
                              Some of my 3d
                                linea
                                Pete If my modest skills are useful to you I need the work so would love to help you in the future. Here is an example of yesterdays tedium.
                                • soloS Offline
                                  solo
                                  Excellent!
                                  It's great to know that there are many talented folks available for any urgent work or even standard projects that need a lot of CAD to SU modeling.
                                  I know Mike Lucey has a business plan that he is working on, but I do not have any details as yet, but this thread could be a benefit to gauge availability of freelancers for this type of work.
                                    lucifer1101
                                    im glad you find us all soo talented...
                                    if you want when i finish my current project you could supply me with some plans and elevations and i would work on it as an example of what i do....
                                    if you want??
                                    Some of my 3d
                                      Not sure but this seems preferable to working from the light, scanned pencil sketches I frequently get. there's barely enough dimensions to build the model and sometimes the dimensions given won't work. I make do.
                                      • Mike LuceyM Offline
                                        Mike Lucey
                                        This makes for interesting reading. Thanks Pete, for kicking it off. And YES, we are working on something that may be of interest in this line of work. I will say no more until its in, at least a Beta form.
                                        Mike
                                          caddict
                                          galbavy, if your elevations are actual su lines/faces, it must be possible to select all the window and door outlines and moving them across (with axis lock) place them on the appropriate wall?
                                          what was the method you read about earlier?
                                          • tinanneT Offline
                                            tinanne
                                            Hi Pete,
                                            Add me to the list also. 😄
                                            Executive Director : American Society of Architectural Illustrators
                                            AIP 30 Competition opens soon. ASAI.org
                                            Architectural Rendering
                                            • 1 / 2
