    Right-click causes 'bong' error sound on mac
    26 Posts 10 Posters 22.9k Views 10 Watching
    • TIGT
      I have just retested both versions and there are only 'beeps' when you make an incorrect choice in one of the tools...
      Can you explain the exact circumstances under which you hear the 'beeps'...
      There are NO RB files in the links - just RBZ files.
      When you download these RBZ files how are you 'installing' them ??
      The definitive versions of both units versions of the [old] tool have been linked for almost 5 years !
      They work for everyone else, so maybe you have some really old file versions clogging up your system, and therefore you need to delete manually them before attempting a 'good' install... ???
      • P
        paulofukuta
        403 Forbidden
        (sketchucation.com)
        This link that you posted in one of the messages above leads us a post there are the following links:
        Metric:
        http://sketchucation.com/forums/viewtopic.php?p=519210#p519210
        Imperial:
        http://sketchucation.com/forums/viewtopic.php?p=556663#p556663
        I use the metric system ... Clicking on the metric system link, we go to a third post that shows two files:
        HouseBuilder_metric_12 [TIG] .zip
        HouseBuilder_metric_12 [TIG] .rbz
        As I said earlier, I have already tested these two files and both files are beeping. The RBZ file, I install by opening SketchUp 2019> Windows> Extension Manager.
        Already the ZIP file, I always unzipped and installed manually, copying and pasting in the plugin folder:
        πŸ˜„ \ Users \ ... \ AppData \ Roaming \ SketchUp \ SketchUp 2019 \ SketchUp \ Plugins
        The beep happens every time I right click on any object. So, for example, if I want to right-click to create a group / component or work with dynamic components, the beep will sound. Something that does not happen when the plugin is not installed. The beep also happened when I moved the mouse arrow over the Edit button. But it seems that it is no longer happening now. I do not know is because of the installation of another version of the plugin. When I right-click on any name inside the Outliner window the beep sounds too. So, I believe that for everything that the right button has a function, there will be the beep sound.
        I use SketchUp 2019 in Portuguese, I don't know if this can interfere with the plugin's operation. And also tested in Portuguese version 2016, but the same thing happens.
        Maybe this beep is like that, as you said, "when you make an incorrect choice". And I'm interpreting it as something nonstandard.
        Thank you for your help! πŸ˜„
        • TIGT
          I apologize !
          I have managed to replicate an odd beep on a right-click selection...
          Relating to metric HouseBuilder
          I'll look at it again...
          Its code is obfuscated, so it's not so easy to see...
          • TIGT
            I've updated the metric version's RBZ here: http://sketchucation.com/forums/viewtopic.php?p=519210#p519210
            It is now 'bong' free - I hope !
            I've also deleted the ZIP version to avoid confusion...
            • P
              paulofukuta
              Beep never more !!!
              Thank you so much! πŸ˜„ πŸ˜„ πŸ˜„
              • S
                sanjusasal
                I uninstall House Builder Plugin and a all good now πŸ˜„
                • 2 / 2
