    Fixing Colours
    5 Posts 3 Posters 477 Views 3 Watching
    • K
      kitewader
      Is it possible to fix colours irrespective of the camera angle. I'm trying to colour a floor in different colours but when i change the viewpoint the hues change. Can I stop this happening??
      • ToboboT
        Tobobo
        Can you post some images to help a slow person like me understand?
        Until then is there different sun and shadow settings between the two settings?
        Toby
        Philippians 4:13
        • J
          Jim
          Mike,
          Open the Shadow Settings, and select Use sun for shading option. Finally, reverse the Light and Dark sliders. That will even out the shading.
          • K
            kitewader
            Jim - Brilliant!!
            I've been clicking around for ages with absolutely no success - your suggestion has solved the problem. Is there a way of applying these settings to all the scenes, or do I have to set each scene individually??
            • K
              kitewader
              Toby, Thanks for your help as well.
