Fixing Colours
Is it possible to fix colours irrespective of the camera angle. I'm trying to colour a floor in different colours but when i change the viewpoint the hues change. Can I stop this happening??
Can you post some images to help a slow person like me understand?
Until then is there different sun and shadow settings between the two settings?
Mike,
Open the Shadow Settings, and select Use sun for shading option. Finally, reverse the Light and Dark sliders. That will even out the shading.
Jim - Brilliant!!
I've been clicking around for ages with absolutely no success - your suggestion has solved the problem. Is there a way of applying these settings to all the scenes, or do I have to set each scene individually?? -
Toby, Thanks for your help as well.
